model_mki_silvia_turborxg
Nissan Silvia Turbo R-X.G
The Nissan Silvia Turbo R-X.G is the flagship luxury specification S12, loaded with features and technology not found on any other model in the S12 lineup. The R-X.G was available as a Coupe or Hatchback model shape and was equipped with the single cam CA18ET engine, ensuring the model didn't step on the toes of Nissan's flagship performance model, the Turbo RS-X. Nissan was proud of all the electronic additions to the R-X.G's luxury specification, proudly claiming a coupe of firsts with their technology. The fitting of an electronic sunroof with tilt and retract was a first for such technology fitted to a production car in Japan. Retractable headlights fitted with a washer & wiper combination and an electric multi-adjustable seat were claimed to be a world first!
Model
Body Version MKI
Body Shape Coupe / Hatch
Market Japan
Production Year 1983-1986
Identification
VIN Plate Identification Data
View S12 Identification Page
Carries the “J' designation in MODEL to identify Luxury Specification.
Specifications
Coupe Hatchback
Length 4430mm
Width 1660mm
Height 1330mm
Wheelbase 2425mm
Front Track 1390mm
Rear Track 1425mm
Ground Clearance 150mm
Vehicle Weight 1090kg (1110kg AT) 1115kg (1135kg AT)
Interior Length 1680mm 1670mm
Interior Width 1380mm 1380mm
Interior Height 1075mm 1075mm
Capacity 5 People
Gross Vehicle Weight 1365kg (1385kg AT) 1390kg (1410kg AT)
Climbing Ability Tanθ 0.47
Minimum Turning Radius 4.9m
10 Mode Fuel Economy
(Ministry of Transport Approved Value)
13.0 (11.0) km/L
Fuel Efficiency at 60km/h Constant Speed
(Ministry of Transport Notified Value)
22.7 (19.5) km/L
Fuel Tank Capacity 53L
Transmission / Clutch (MT) OD 5-Speed Floor Shift / Dry Single Diaphragm
Transmission / Clutch (AT) Nissanmatic Floor Shift / Torque Converter
Steering Type Rack & Pinion Type
Front Suspension Independent Strut Suspension
Rear Suspension Independent Semi-Trailing Arm Suspension
Front Brake Ventilated Disc
Rear Brake Solid Disc
Wheels & Tyres Front & Rear 5Jx14 Steel Wheels, 185/70SR14
Exterior
The flower of specialty sports, dedicated to gourmet driving.
Ahead of the 21st century. High technology is input into the whole body.
  1. New super sound system.
    I addition to a diversity receiving system, electronic tuner, cassette deck, and four rear two-way speakers, it also features the world's first power woofer that utilizes a pole on the rear parcel shelf, allowing you to enjoy dynamic sound.
  2. Electric sunroof with tilt-up mechanism.
    An electrically operated sliding glass sunroof. It has a tilt-up function for quick ventilation, this combination is the first in Japan for the already popular glass sunroof. The feeling of freshness when fully open is exceptional. Of course, it also comes with a sunshade to prevent glare (Coupe).
  3. Aerodynamic body.
    Fully retractable headlights that cut through the airflow, full wheel covers and aluminum road wheels with excellent aerodynamic properties, and the body's thorough use of flush surface, including full doors, achieves an air-resistance coefficient of 0.36 (Coupe) and 0.34 (Hatchback).
  4. Fully retractable headlamps with wipers.
    To maintain its stylish form, the headlights are usually stored inside the hood. They only rise up and light up when necessary. They also come with wipers, this combination is a world first.
  5. Electronic meter.
    The electronic cockpit is equipped with not only a speedometer and tachometer, but also an oil pressure gauge, a voltage gauge, a boost gauge, a drive guide, and more. This is the extent to which the Silvia has become so electronic.
  6. Tilt steering with memory.
    In addition to the normal tilt mechanism, a lifting function has been added to make it easier for the driver to get in and out. When lowered, the memory returns to the original set position. This means there is no need to adjust the tilt after getting in and out.
  7. Keyless entry system.
    This advanced equipment uses a microcomputer to lock and unlock the door, lower the door glass, and unlock the trunk from outside the vehicle without a key. All you need to do is enter a pre-entered code and press a button, so there's no need to worry about theft.
  8. Multi-adjustable seat.
    This multi-seat has eight functions. Of these, the lumbar support, side support, and thigh support are electronically air-operated. It also features an electrically operated lifter. This allows you to find the ideal driving position while providing tight support for your body.
  9. New 4-wheel independent suspension.
    The new suspension further refines Nissan's four-wheel drive system, which has been thoroughly honed through racing and rallies. Matched with the 60 tyres, the car's running performance has been further enhanced.
  10. Drive guide.
    The new system features a control panel set in the cockpit that provides a guide function that tells the direction and distance to the destination, as well as a compass function that tells the direction when you want to drive in a certain direction.
Interior
The cutting edge of car electronics is brought together. Evolution always begins with the Silvia.
Electronic Digital Meter
This instrument panel speaks to the philosophy of a specialty car.
The driver who operates this cockpit will have two privileges: the thrill of driving that can only be experienced in a sports car, and the pride of having the luxurious advanced equipment of a specialty car. It is inevitable that you will need to be prepared to endure jealous stares.
The heart of the new Silvia is an electronic digital meter. The speedometer is in the center, with the water temperature gauge, oil pressure gauge, fuel gauge, and voltmeter on either side, and a tachometer with LEDs on the bottom. A boost gauge and drive guide are newly adopted.
The instrument panel is densely packed for easy viewing. Moreover, the layout is easy to see, and the green night lighting prevents the driver from feeling fatigued. There are also plenty of monitors and warning lights. You can accurately judge the condition of your car, which is a great relief.
Cockpit
  1. Power window switch
  2. Passenger seat ventilation outlet
  3. Glove box
  4. ASCD cruise control monitor
  5. ASCD switch monitor
  6. Windshield washer fluid level warning light
  7. Radiator fluid warning light
  8. Rear defogger with timer operation warning light
  9. Fuel level warning light
  10. Multi-function LCD digital clock
  11. Drive guide operation panel
  12. Air conditioning control panel
  13. Rear defogger switch with timer
  14. Trunk opener switch
  15. Stepless intermittent wiper switch
  16. Electronic digital meter
  17. Leather-wrapped sports steering wheel
  18. ASCD control switch
  19. Retractable headlamp switch
  20. Electric remote control door mirror switch
  21. Door pocket
  22. OD 5-speed floor shift
  23. Power woofer switch
  24. AM/FM high-end electronic tuner
  25. Cassette deck
  26. Drivers seat footrest
  27. Power antenna switch
  28. Cigarette lighter switch
  29. Power window switch
  30. Door pocket
Multi Adjustable Seat
The driving position is impeccable. Now, the Sporty Zone has also achieved comfort.
The world's first! Electric multi-adjustable seat.
What should seats be like in a high-performance car? What should seats be like in a specialty car? The Silvia's seats are full-fledged bucket seats designed based on experience from domestic and international races and rallies. What's more, the higher-grade models are multi-adjustable seats with eight built-in functions. An electric lifter with a 36mm upper drift. Air-operated side support, thigh support, and lumbar support mechanisms… all parts of the body are tightly held in place with just one touch, allowing for sporty driving to your heart's content. The driving position is also perfectly determined.
  1. Headrest vertical adjustment
  2. Headrest front and rear adjustment
  3. Reclining adjustment
  4. Slide adjustment
  5. Lumbar support (electric air type)
  6. Side support (electric air type)
  7. Thigh support (electric air type)
  8. Lifter (electric)
Memory Tilt Steering
Return to Model Overview
model_mki_silvia_turborxg.txt · Last modified: by Matt Castle
