silvia_white_versions
Nissan S12 Silvia White Versions
Japanese Domestic Market Limited Edition Models
Introduced in late 1986, towards the end of the production run of the MKII S12 Silvia in Japan, Nissan introduced 3 special version models. These models were marketed as high-end fashionable variants of the S12 with new luxury features and specifications setting them apart from the rest of the S12 line-up.
These White Version models are the Twin Cam Turbo Full White RS-X, the Turbo Full White R-X, and the R-X White Select.
New all-white special version added to the line-up.
The Silvia-Nissan’s elegant, high-grade personal car has always had a flair for fashion. And now the height of fashion is all white! The all-white treatment is the “in” thing on wheels. People who care about cars and fashion know this. An all-white color scheme is clean, refreshing and it reflects your good taste and sense of style. The Silvia’s exciting aerodynamic profile looks its best in white with subtle shadows rounding the shapely contours. Here is unsurpassed beauty that goes perfectly with the Silvia’s outstanding driving capability with its twin-cam turbocharged engine for all the power you can handle. The Silvia feels good in your hands on the road and looks great too!Nissan Silvia Brochure
Model
Body Version MKII
Body Shape Coupe Only
Market Japan
Production Year 1986-1988
All White Version Silvias carry the X special character designation in the Model Code on the VIN plate.
See Identification...
Specifications
Full White RS-X Full White R-X R-X White Select
Size
Length (mm) 4460 4460 4460
Width (mm) 1670 1670 1425
Height (mm) 1330 1330 1425
Interior Length (mm) 1680 1680 1425
Interior Width (mm) 1380 1380 1425
Interior Height (mm) 1075 1075 1425
Wheelbase (mm) 2425 2425 1425
Front Track (mm) 1390 1390 1380
Rear Track (mm) 1425 1425 1360
Ground Clearance (mm) 155 150 150
Weight / Capacity
Vehicle Weight (kg) 1180 (MT), 1200 (AT) 1130 (MT), 1150 (AT) 1050 (MT), 1070 (AT)
Capacity 5 People
Gross Vehicle Weight (kg) 1455 (MT), 1475 (AT) 1405 (MT), 1425 (AT) 1325 (MT), 1345 (AT)
Fuel Tank Capacity 53L
Performance
Engine CA18DET CA18ET CA18S
Minimum Turning Radius 4.9m
Fuel Consumption (km/l)
60km/h constant speed (Minitstry of Transport notified value)
18.9 (MT), 17.2 (AT) 22.7 (MT), 19.5 (AT) 22.0 (MT), 19.5 (AT)
Devices
Transmission / Clutch (MT) 5-Speed Manual with Overdrive on 5th
Transmission / Clutch (AT) Power Economy Automatic Switching Electronically Controlled 4-Speed Lock-Up with Overdrive 4-Speed Lock-Up Automatic with Overdrive 4-Speed Automatic with Overdrive
Steering Type Rack & Pinion
Front Suspension Independent MacPherson Strut Type, Coil Spring, Stabilizer Bar and Tension Rods
Rear Suspension Independent Semi Trailing Arm 4-Link Coil Type (Solid Rear Axle)
Front Brake Disc
Rear Brake Disc Drum
Wheels 6JJ x 15 steel wheels with wheel covers 14 inch steel wheels with wheel covers
Tyres 195/60 R15 86H Potenza RE71 185/70SR14
Model Full White RS-X Full White R-X R-X White Select
Transmission MT AT MT AT MT AT
1st 3.592 2.842 3.592 2.842 3.321 2.842
2nd 2.057 1.542 2.057 1.542 1.802 1.542
3rd 1.361 1.000 1.361 1.000 1.308 1.000
4th 1.000 0.686 1.000 0.686 1.000 0.686
5th 0.821 - 0.821 - 0.838 -
Reverse 3.657 2.400 3.657 2.400 3.382 2.400
Final Drive 4.375 4.375 3.700 3.700 3.700 3.889
The Twin Cam Turbo Full White RS-X is the flagship model of the new white versions. With the all-white paint split by a sporty red and grey belt-line and special decals on the doors, the Full White RS-X is a new look for the Silvia range. Equipped with the PLASMA-CA18DET and an all new interior and sound system, Nissan presented this model as the sportiest and most comfortable Silvia in their line-up.
White for freedom, status, performance and quality. White speciality. Introducing the Full White RS-X.
This form shines vividly in the light. The interior has been upgraded, and uses fine quality double Russell cloth for the seating. Moreover, it includes JBL speakers and cassette deck, a powerful electronic tuner and a full audio system.Nissan Silvia Brochure
The Silvia is a car that embodies high elegance and a graceful sporting spirit. It is a specialty sport for people who know cars inside and out. The unparalleled beauty and the outstanding performance of the twin-cam turbo will even excite you.
A new personality has been born, clad in full white.
White is status. White is freedom. White is performance. Nissan Silvia Brochure
Identification:
ID Code
TYPE E-S12
MODEL BS12HFTX (MT)
BS12HATX (AT)
COLOR,TRIM 326, K
ENGINE CA18DET
TRANS.,AXLE FS5W71C, RC43 (MT)
L4N71B, RC43 (AT)
A new status - Full White.
1. AM/FM electronic tuner (25W + 25W) / cassette deck (Dolby Metal compatible) / JBL speakers (4 speakers): Audio system exclusive to the Full White model. Powerful sound reverberates through the cabin.
2. Coloured urethane bumpers (front and rear): The front is also equipped with a coloured spoiler.
* (Bumper strips are black on every standard model MKII Silvia)
3. Electric remote control coloured door mirrors.
* (Door mirrors are black on every standard model MKII Silvia)
4. Coloured door handles.
* (Door handles are black & chrome on every standard model MKII Silvia)
5. Body side decal.
6. Dedicated full wheel cover.
7. 195/60R15 86H Potenza RE71 radial tyre.
Other main equipment:
  • Front laminated bronze glass
  • Power steering
  • Tilt steering
  • One-touch power windows
  • Footrest
  • Bucket seats (North American double Russell fabric)
  • 4 wheel disc brakes
The Turbo Full White R-X sits in the middle of the new 3 model White Version series. It is based on the Silvia Turbo R-X and it carries the same features and accessories as the flagship Full White RS-X, but is instead fitted with a CA18ET engine. The single camshaft CA engine is rated at 135PS instead of the Full White RS-X’s 145PS. The Full White R-X is fitted with a brown interior the same as the Silvia Turbo R-X.
The Turbo Full White R-X is not pictured in any of the Nissan marketing material.
Pictured above is the brown interior from the Silvia Turbo R-X which is fitted to the Turbo Full White R-X.
Identification:
ID Code
TYPE E-S12
MODEL S12HFTX (MT)
S12HATX (AT)
COLOR,TRIM 326
ENGINE CA18ET
TRANS.,AXLE FS5W71C, RC37 (MT)
L4N71B, RC37 (AT)
R-X White Select
The R-X White Select is the base model of the White Versions and is quite basic compared to its superiors. Equipped with a CA18S carbureted CA engine, it is rated at 100PS. The interior is also of lower specification, missing out on the special black Russel Cloth treatment of the Full White RS-X, instead featuring the brown interior equivalent to the standard MKII R-X Silvia. The R-X White Select is also stripped of the exterior finishing parts, the front lip, side and rear pods.
Introducing the new Coupe R-X White Select. Let your white fashion dance brightly.Nissan Silvia Brocure
Identification:
ID Code
TYPE E-JS12
MODEL JS12HFX (MT)
JS12HAX (AT)
COLOR,TRIM 326
ENGINE CA18S
TRANS.,AXLE FS5W71B, HE38 (MT)
L3N71B, HE38 (AT)
1. Electric remote control coloured door mirrors.
2. Coloured urethane bumbers (front and rear).
3. Body side decals
4. Dedicated full wheel covers.
5. Cassette deck (Compatible with Dolby Metal).
Other Major Equipment:
  • Front bronze glass with washer-linked wipers.
  • AM/FM Electronic tuner (15W + 15W) + 4 speaker FM diversity.
  • Power steering.
  • Tilt steering.
  • Power windows.
  • Driver seat lumbar support.
  • 185/70SR14 radial tyres.
View MKII Silvia (Extended) PDF (25.2mb)...
View Full White RS-X Brochure PDF (5.6mb)...
View Full White RS-X Advertisement PDF (3.1mb)...
Return to Model Overview...
silvia_white_versions.txt · Last modified: by Matt Castle
