model_mkii_gazelle_sgl
MKII Nissan Gazelle SGL
Nissan Australia released the MKII Gazelle into the market in 1986, however the options would be severely limited in comparison to its MKI predecessor. For starters the new MKII was only offered in one body configuration, available in hatchback only with the SGL trim package. Colour options were limited to two-tone red over grey or two-tone dark blue over silver. Interior was limited to grey only, but the option of a manual or automatic transmission still remained. The MKII Gazelle did not sell very well at all in Australia, making this model very rare and unique.
Feel a special kind of freedom every time you drive.Nissan Gazelle Australia Brochure
Body Version MKII
Body Shape Hatch
Market Australia
Production Year 1986-1988
Identification
Specifications
Length (mm) 4350
Width (mm) 1660
Height (mm) 1330
Wheelbase (mm) 2425
Front Track (mm) 1380
Rear Track (mm) 1360
Ground Clearance (mm) 160
Vehicle Weight (kg) 1120
Capacity 5 People
Fuel Tank Capacity 53L
Transmission / Clutch (MT) 5-Speed Manual with Overdrive on 5th, 4.111 Final Drive
Transmission / Clutch (AT) 4-Speed Automatic, Lock-Up Torque Converter, 4.111 Final Drive
Steering Type Rack & Pinion Power Steering
Front Suspension Independent MacPherson Strut Type, Coil Spring, Stabilizer Bar and Tension Rods
Rear Suspension Independent Semi Trailing Arm, Coil Spring Shock Absorbers and Stabilizer Bar
Front Brake Disc
Rear Brake Disc
Wheels & Tyres 6JJ x 15 spoked alloy wheels, 195/60 R15 steel radial tyres
Gear Manual Auto
1st 3.321 2.842
2nd 1.902 1.542
3rd 1.308 1.000
4th 1.000 0.686
5th 0.838
Reverse 3.382 2.400
Final Drive 4.111 4.111
Nissan Gazelle MKII
Stylish. Superbly equipped. Free spirited. That's today's Nissan Gazelle. Every time you drive it you will feel a special kind of freedom. Because Nissan Know-How has made Gazelle a special kind of personal car.
On the outside, Gazelle is clean and lean. From retractable quartz halogen headlights to rear spoiler, it's styled to slip through the wind.
Inside, Nissan has carefully considered your every need. With body-contour sports bucket seats, power windows and full instrumentation, Gazelle is an uncompromising display of luxury. Standard features include AM/FM radio/cassette with electronic tuning and 4 speakers, cruise control, power side mirrors, remote fuel and deck lid release, full console and adjustable front seat headrests. In the rear, you have split-fold seats to make the most of Gazelle's liftback versatility.
On the road, Nissan Know-How means smooth performance from a fuel injected 2 litre engine teamed with your choice of 5-speed manual or 4-speed automatic with lock-up torque converter. And you drive sure and easy with speed sensitive power steering, power-assisted 4-wheel disc brakes and an independent suspension system that hugs the road. Come and drive Nissan Gazelle and discover how a car can do a whole lot more than just get you there.
Swift. Nimble. Smooth.
From the Oct. 1983 - Mar. 1985 Nissan Gazelle Australia Brochure
Beneath Gazelle's sleek good looks beats a powerful heart: a brand-new Dual Ignition, Fuel-Injected 2-litre, 4 cylinder OHC engine that is the very latest in lightweight, fuel efficient design from Nissan.
It has an exceptional power-to-weight ratio, achieved through the use of the most advanced lightweight alloys available today. Hemispherical combustion chambers and “high swirl” intake ports, combined with electronic Fuel Injection and Dual Ignition, help achieve an outstanding level of power and torque. Dual Ignition simply means that each cylinder has two spark plugs, so fuel burn is faster, more thorough, resulting in greater responsiveness and fuel savings with less emission.
In transmissions, a smooth 5-speed manual with 5th gear overdrive is standard. The all-new optional 4-speed overdrive automatic incorporates a “lock-up” torque converter. This means that from 78kph in top gear, the torque converter “locks-up” so that drive is direct from engine to transmission. Thus eliminating conventional automatic slippage and reducing engine speed for economy.
Gazelle scores high in road handling ability. McPherson Strut front suspension, anti-sway bars front and rear, rack and pinion steering and steel radial tyres give it superior handling ability for spirited driving. The combination front disc-rear drum brakes, with disc pad wear indicator, assure smooth, controlled stopping power.
The overall result is a technically advanced blend of performance, comfort and handling. With sophisticated styling and luxury to please.
Equipment & Options
1. Tilt adjustable steering wheel.
2. Sunroof.
3. Retractable quartz hologen headlights.
4. Remote control rear deck release with wiper/washer.
Appearance/Comfort/Convenience Features
Exterior
Manual Sunroof
Retractable Quartz Halogen Headlights
Alloy Wheels
Wide Bodyside Mouldings
Rear Wiper/Washer
Heated Rear Window
Rear Spoiler
Body Coloured Bumper Bars
Mudflaps (Front & Rear), including anti-stone chip moulded panel on rear
Interior
Automatic Cruise Control
Power Windows
AM/FM Radio with Electronic Tuning
Stereo Cassette Player (Dolby)
4 Speakers
'Diversity' Antenna for Constant FM Signal Strength
Power Operated LH & RH Exterior Mirrors
Time Delay Interior Lighting
Front Bucket Sport Seats, Fully Reclining
Drivers Seat Lumbar Support
Front Passenger Seat 'Walk-In' Device for Rear Seat Access
Split Fold Rear Seat (50/50)
Luxury Cloth Seat Trim
Power Steering
Instruments; Speedometer, Tripmeter, Tachomenter, Fuel Gauge, Digital Clock.
Carpeted Load Area
Full Floor Carpeting
Side Window Demist Vents
Luxury Velour Cloth Door Trim
Adjustable Front Seat Head Restraints
Remote Control Fuel Lid / Boot Release
Day / Night Mirror
Moulded Cloth Headlining / Sunvisors
Low Fuel / Door Ajar Lamps
Full Console
Carpet Kickpads
Door Map Pockets (LHS/RHS)
Front / Rear ELR Seat Belts
Colour & Trim
Colour Code Colour Name Interior Colour
561 Dark Blue / Silver Grey
560 Red / Grey Grey
Colour/Trim Combination
Grey (K) interior trim is fitted with both exterior colours.
See Also; Colour Database
View Original Brochure - 33.1mb PDF > >
Return to Model Overview
model_mkii_gazelle_sgl.txt · Last modified: by Matt Castle
