Nissan Silvia 50th Anniversary Version
The MKI Nissan Silvia 50th Anniversary Version is a Japanese-Market special edition released in 1984 to celebrate Nissan's 50th Anniversary. It was limited to 500 units nation-wide and was only available in the coupe body shape.
The car is based on the MKI Silvia Turbo R-X.G, the Silvia line-up's luxury specification model, however has some noticeable changes. The main difference is the new white-over-gold two-tone paint option, a paint scheme not available on any other model option. Other new additions include matching gold-painted wheels, 50th anniversary badges on the front grill and rear boot-lid, and gold-stitched and badged seats with matching interior trim. A unique 50th Anniversary Version key was also included with this special edition Silvia.
The new Silvia, with its striking style and dramatic appearance, has created a stir among car fans. Now, to celebrate Nissan's 50th Anniversary, a super luxurious Silvia has been released, which adds a number of different specifications to the high-end model of the New Silvia.Nissan 50th Anniversary Brochure
The ultimate top-of-the-line Silvia is finally here. This is an extremely luxurious model that will be the perfect finale to Nissan's 50th anniversary.
Only 500 of this special commemorative car will be produced nationwide. Don't miss out on the amazing driving experience and luxurious equipment that only the chosen few can enjoy. This is your last chanceโฆ
Model
| Body Version | MKI |
| Body Shape | Coupe Only |
| Market | Japan |
| Production Year | 1984 |
Identification
VIN Plate Identification Data
View S12 Identification Page
| ID | Code |
| TYPE | E-S12 |
| MODEL | S12HFTK (MT) |
| S12HATK (AT) | |
| COLOR,TRIM | 117, (Interior Unknown) |
| ENGINE | CA18ET |
| TRANS.,AXLE | FS5W71B, RC37 (MT) |
| L4N71B, RC37 (AT) |
Carries the โK' designation in MODEL to identify 50th Anniversary Version.
Carries unique COLOR,TRIM codes specific to this model. 117 White/Gold colour code.
Specifications
| Length | 4430mm |
| Width | 1660mm |
| Height | 1330mm |
| Wheelbase | 2425mm |
| Front Track | 1390mm |
| Rear Track | 1425mm |
| Ground Clearance | 150mm |
| Vehicle Weight | 1090kg (1110kg AT) |
| Capacity | 5 People |
| Gross Vehicle Weight | 1365kg (1385kg AT) |
| Climbing Ability | Tanฮธ 0.47 |
| Minimum Turning Radius | 4.9m |
| 10 Mode Fuel Economy (Ministry of Transport Approved Value) | 13.0 (11.0) km/L |
| Fuel Efficiency at 60km/h Constant Speed (Ministry of Transport Notified Value) | 22.7 (19.5) km/L |
| Fuel Tank Capacity | 53L |
| Transmission / Clutch (MT) | OD 5-Speed Floor Shift / Dry Single Diaphragm |
| Transmission / Clutch (AT) | Nissanmatic Floor Shift / Torque Converter |
| Steering Type | Rack & Pinion Type |
| Front Suspension | Independent Strut Suspension |
| Rear Suspension | Independent Semi-Trailing Arm Suspension |
| Front Brake | Ventilated Disc |
| Rear Brake | Solid Disc |
| Tyres Front & Rear | 195/60R15 86H |
Cockpit
Comprehensive electronics. A sporty and luxurious specialty cockpit.
The cockpit of the Silvia, which brings together Nissan's most advanced technology, has been further enhanced with luxurious special equipment to commemorate the 50th anniversary. These include an optical communication switch-embedded steering wheel with ASCD and audio switches built into the steering wheel, a voice warning system that notifies you of warnings and information with a female voicem and a luxurious super sound system newly equipped with an electronic tuner with program reservation. Furthermore, electronic digital meters, power windows, and a multi-function digital clock, which are at the forefront of car electronics, are also standard equipment.Nissan 50th Anniversary Brochure
Interior
It creates not only a sporty atmosphere but also the ultimate relaxation.
Full-fledged bucket seats are available to hold the powerful power of the PLASMA CA18ET engine. Moreover, they are electrically adjustable multi-adjustable seats with eight built-in functions. This allows you to adjust the seat to fit your body perfectly with just one touch, ensuring the optimal driving position and helping to reduce fatigue. The seat fabric is made of high-quality plain weave. The same material is used for the door trim, creating a sense of elegance befitting a specialty car.Nissan 50th Anniversary Brochure
Equipment
A - Optical communication non-rotating switch built-in steering wheel.
The Super Sound System switch and ASCD switch are built into the center of the steering wheel and are operated by an optical communication system. The center part does not move even when the steering wheel is operated, so it is a non-rotating type that keeps the same position.B - Rain sensor type fully automatic wipers.
This is a convenient mechanism in which the sensor detects changes in rainfall and automatically operates at the optimal time.C - Keyless entry system.
This revolutionary new mechanism allows you to open and close the doors, open the windows, and open the trunk without using a key, all by using the operation buttons set on the outside handle.Nissan 50th Anniversary Brochure
D - Electronic tuner with program reservation.
If you set it to any time, it will turn on at the specified time. Up to 10 programs can be reserved.Super sound system.
The 20W+20W high power amplifier has a built-in diversity reception system. It provides powerful sound with a metal cassette deck with Dolby NR and the world's first power woofer.E - Drive guide.
If you input the direction and distance to your destination, the system will determine the direction to your destination while checking the cars position. The information is displayed on the instrument panel.Nissan 50th Anniversary Brochure
F - Electrically adjustable multi-seat.
Eight functions are incorporated, including electric lifters and electric air lumbar support, thigh support, and side support. The seat fabric is made of luxurious plain weave. The seat back has the 50th anniversary mark on it.G - Bronze Glass.
It blocks direct sunlight and protects privacy. It also has a luxurious appearance.H - Turbo Sticker.
This is a turbo sticker that clearly shows off the powerful turbo power.I - Aluminum road wheels and 60 tyres.
The 195/60R15 86H radial tyres provide even more power than the engine, and are fitted together with bold gold aluminum road wheels.Nissan 50th Anniversary Brochure
| 50th Anniversary Special Commemorative Equipment | Main Standard Equipment |
| 50th Anniversary Car Badge | Electric Remote Control Door Mirror |
| 50th Anniversary Rear Emblem | Electronic Digital Meter |
| 50th Anniversary Key | Drive Guide |
| Special Paint Colour (White/Gold Two-Tone) | Boost Meter |
| Bronze Glass | Illumination Control |
| 195/60R15 86H Tyre | Passenger Seat Vanity Mirror with Sun Visor |
| Gold Aluminum Road Wheel | Large Center Console |
| Turbo Sticker | Room Lamp With Spot Lamp |
| Exclusive Special Seat Material | Drivers Seat Footrest |
| Door Trim Made From Same Material As Seats | Metal Compatible Cassette Deck with Dolby |
| Raindrop Sensing Fully Automatic Wipers | Power Woofer System |
| Optical Communication Non-Rotating Switch Built-In Steering Wheel | Diversity Reception System |
| Voice Warning (Voice Synthesis Information) | One-Touch Power Window |
| Multi-Functional LCD Digital Clock | |
| ASCD | |
| Rear Defogger with Timer | |
| Tilt Steering with Memory | |
| Power Steering | |
| Multi-Adjustable Seat | |
| Large Coloured Urethane Bumper | |
| Keyless Entry System | |
| 4-Wheel Disc Brake | |
| Rear Stabilizer |
