MIL Consult Or GST Fault
11 P0340 Crank Angle Sensor/CMP Sensor
12 P0100 Air Flow Meter/MAF Sensor
13 P0115 ECT Sensor
14 P0500 VSS
21 P1320 Ignition Signal
22 P0505 Fuel Pump
23 P0605 Idle Switch (On/Off Diagnosis)
24 P0400 Throttle Valve Switch
25 P0150 ISC Valve
28 P1900 Cooling Fan Circuit (Overheat)
31 P0325 ECM
32 P1401 EGR Function
33 P0402 HO2S
34 & 37 P0130 Knock Sensor
35 P0150 Exhaust Gas Temperature Sensor
36 P0402 EGRC-BPT Valve
38 P0150 LH Bank Closed Loop (B2)
41 P0110 IAT Sensor
42 P0180 Fuel Temperature Sensor
43 P0120 TP Sensor
45 ------- Injector Leak
47 P1335 CKP Sensor
51 ------- Injector Circuit
53 P0130 O2S
54 P0600 A/T Control
55 P0000 No Malfunction
63 P0306 No. 6 Cylinder Misfire
64 P0305 No. 5 Cylinder Misfire
65 P0304 No. 4 Cylinder Misfire
66 P0303 No. 3 Cylinder Misfire
67 P0302 No. 2 Cylinder Misfire
68 P0301 No. 1 Cylinder Misfire
71 P0300 Random Misfire
72 P0420 TWC Function RH Bank
73 P0430 TWC Function LH Bank
76 P0170 Fuel Injection System Function RH Bank
77 P0136 Rear HO2S Circuit
82 P0335 CKP Sensor
84 P1605 A/T Diagnosis Communication Line
85 P1110 VTC Solenoid Valve Circuit
86 P0173 Fuel Injection System Function LH Bank
87 P0443 Canister Control Solenoid Valve Circuit
91 P0135 Front HO2S Heater Circuit RH Bank
94 P1550 TCC Solenoid Valve
95 P1336 CKP Sensor
98 P0125 ECT Sensor
101 P0155 Front HO2S Heater Circuit LH Bank
103 P0705 PNP Switch Circuit
105 P1400 EGR And EGR Canister Control Solenoid Valve
108 P0443 Canister Purge Control Valve Circuit
----- P0600 Continuous Improper A/T Control Unit Voltage
95 Pathfinder & 300ZX
second_love
- Name: trace
- Car: 200sx
is this for vg30e or de?
