Umai's S12
Umai's S12
Post by Umai Naa!! »
Hooray!
Scored those Tomei/RS*R extractors for Y3,000 (approx $40-$50AUD). Another $300 on top of that will get them into the country :)
Sadistic Moocow - MSN wrote:im usually naked anywayclothes are for rich ppl
Umai's S12
The official bill for the Tomei Extractors is $247.47 shipped to me :)
Seriously, you cannot get them new for that, let alone made locally.
Car: CA18DET S12 Hatch
Umai's S12
Post by al3x »
who did you use to import them?
Umai's S12
www.JesseStreeter.com
I wouldn't use anyone else. If anyone is curious as to what the commission on them was, it was Y1000.
Umai's S12
Hooray!! My extractors turned up!!
Also, the car has a working handbrake now :)
DRIFTKID
Umai's S12
Post by DRIFTKID »
how did you go abouyt the hand brake?
RIP GAZELLEBuy my parts!!!
Umai's S12
Second-hand properly-adjusted TRX S3 handbrake shoes with heaps of meat on them, new discs, and a properly-adjusted cable (Read: maxed-out adjuster!).
I wouldn't rely on it for skids, but it seems to hold the car just fine. The ratchet is at full-extension, though.
Car: Nissan Gazelle
Umai's S12
Post by Candellan »
I had a closer look at the "adjustment" on mine & all they did was put a nut behind the central pivot to take out as much slack as possible. Like you said it holds on a hill, but it's full ratchet (which I can't actually do strapped into the Bride seat). Who needs a handbrake at the track anyway, a rock works just as well in the pits.
Umai's S12
Yeah, I never use it in the pits anyway. Given the heat, it's possible to weld the shoes to the drums if you're not careful.
Car: Nissan Gazelle RS-X
Umai's S12
Post by james »
Umai Naa!! wrote:Yeah, I never use it in the pits anyway. Given the heat, it's possible to weld the shoes to the drums if you're not careful.
That's actually quite funny to witness but annoying to have happen to you!
