Umai's S12
Umai's S12
Post by Umai Naa!! »
The pile of parts I've aquired:
'85 Dark Blue/Light Blue Live axle GL Auto Hatch
Engine:
S13 CA18DET
Remote oil filter kit
AE90-series Corolla oil cooler
Tomei Adjustable Cam Gears
Tomei Heavy Duty Valave Springs
Tomei ProCam 270deg 8.8mm cams
Micro-Tech LT8S ECU and CA18DET-specific harness
Cometic 1.3mm MLS head gasket
Growly Custom Machining billet alloy CAS bracket
Random Nissan Genuine CA18DET seals, gaskets and studs (Leftovers from Y61 Patrol EGR racalls, and Piggie rebuild)
Tomei/RS*R extractors
Driveline:
S13 CA 5-speed
Nismo H190 1.5-way LSD
Series 3 910 Bluebird TRX rear axles
S12/13 hybrid tailshaft
Black urathane gearbox mount
Suspension:
ISC 8kg S13 front coilovers
S13 front hubs
S13 lower control arms
S13 Whiteline 27mm adjustable front swaybar
Noltec front swaybar bushes
Noltec Lower Control Arm Bushes
K-Mac 22mm rear swaybar
S14 castor rod brackets
Noltec rear swaybar bushes
S14 swaybar mounts
Brakes:
R32 GTS-t 4-piston Calipers
Pistonfreak Master Cylinder Brace
Silver alloy drift button
EBC Red Stuff front pads
EBC Red Stuff rear pads
R32 GTS-t RDA slotted front rotors
910 Bluebird TRX Series 3 slotted rear rotors
910 Bluebird TRX Series 3 rear calipers
Custom braided lines
R33 GTS25T BM44 master cylinder, with booster removal plate, and shorter pushrod
Misc:
Triple G Custom 4-pt welded in halfcage
2x 16x6.5 +20 Impul ProSpokes
2x 16x7 +25 Impul R1s
2x 16x8 +25 Impul R1s
Numerous stickers
MK2 Grille
MK2 Mud flaps
Sinex hatch wing
2x 16x7 +25 Rays Engineering Volk Racing Group A Evolution 2s
MK2 bonnet
MK2 facia
MK2 park lights
Greddy 60mm white-faced electric water/oil temp and oil pressure gauges
MK2 front lip
Sadistic Moocow - MSN wrote:im usually naked anywayclothes are for rich ppl
Car: CA18DET S12 Hatch
Umai's S12
Post by al3x »
Hey dean,
16x7 +32 Enkei RS-E
16x8 +32 Enkei RS-E
Do they sit on the guards or sit in?
Umai's S12
They sit a bit too far in, unfortunately.
Gonna get some 20mm bolt-on spacers for them.
Shinigami
Umai's S12
Post by Shinigami »
cant wait till your done :P
pics are definatly needed :D
John
** Drive It, Like You Stole It **ImageTouge and Drift Lover >.<CA18de 1984 Gazelle --> SOLDCA18det 1990 PS13 180sx -->Daily/New Piggy
= SR S13 =
Umai's S12
Post by = SR S13 = »
i want pics dean
Umai's S12
Post by gerryb »
Well done on the H190 1.5 way LSD how'd you get hold of that baby?
(Who'd you have to waste to get it he he?)
Have you got the short mkII clear parkers to go with the grille. I'm told they are still available to be ordered from nissan. A Canadian guy on club s12 has ordered them, if you haven't got them look for his post about it on club s12, to see if you can chase up the part numbers. The aust. mk II's came out with them so you should be able to order them through nissan Australia.
Umai's S12
Post by Fester »
gerryb wrote:Well done on the H190 1.5 way LSD how'd you get hold of that baby?
Damn, I knew I forgot to pick something up while I was visiting you Dean!
Picture the scene... the redhead disappearing in a cloud of tyre smoke and mad cackling... Dean lying in his driveway, bleeding and twitching with his hands clenching and unclenching around the memory of holding the Nismo LSD...
Umai's S12
I'm buying an assult rifle.
For protection ;)
Everyone, pics are coming. Trust me.
Gerry, I rang a bloke who is an agent for KAAZ. He made some calls, and a week later, an LSD was heading to my house. I've got the part numbers for the parkers, gonna try and order them next week. I tried giving them the VIN number you gave me, but it didn't help, unfortunately.
Shinigami
Umai's S12
Post by Shinigami »
the H190 LSD must of killed those pockets of yours lol :P
John
Umai's S12
At $1650incl freight, it was no bargain.
