Long story short I'm starting again on the whiteboard, here is the plan
***Body***
Matte black respray, straightened panels and the guards will be rolled
***Wheels/tyres***
Whatever I can fit under the pumped guards, probably some s13 16 or 17" with at least 235 or 245 on the rear.
***Suspension***
s13 coilovers, BC S12 Kit
r31 adjustable caster arms and new bushings
s13 LCA
s13/r32 rack ends
s13/r32 tie rods
s13 swaybar
(all this is long overdue)
***Motor***
Crack tested
Bored
Decked
-Nitto 2.2 Stroker kit-
Nitto 4340 Crank
Nitto 4340 H-beam rods
Nitto/JE 87mm pistons
ARP Head and bottom end studs and bolts
Cometic gasket kit (MLS)
Cams - !!!!UNDECIDED SO I NEED SOME INPUT!!!
Cam gears
Rocker stopper kit
New timing chain
New oil pump
Tomei ARMS turbo, unsure of size or trim yet..... would like some input
Decent injectors, I'm open to suggestions
044 + surge tank
Management, Link or Power FC mabey
Basicly it is still going to be a street car but probably just weekend and track duties, still want to run pump fuel and basicly want a genuine 400-500rwhp menacing night time weapon.
heres some pics of the pulldown!
FFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
