Rannerz presents: The G-Zelly
- RannerZ
- swampdonkyy
- Name: Brad
- Car: S12 SILVIA FISCO
Just started taking more parts off of your car Luke, to work out what more parts you will have to buy!
As you can see your ball joints in you lca's are stuffed & your sway bar mount is broken! you will need all new bushes for the frount end because the oil & age stuffed all of them! I allso removed the rest of the a/c
- swampdonkyy
- Name: Brad
Dave wrote:Seriously if I cleaned this, there would be so much complaining when this thread went from 17 pages to 2...
Just clean it up a bit. No 1 will mind.
A few more bits came off, so when the fj x member gets here it can go streight in!
- RannerZ
Wow this is looking so much better.
Thanks Brad.
James: The engine bay is going gloss black.
Thanks Brad.
FJ20 YO!- swampdonkyy
- Name: Brad
^+1 makes things a HEAPS hotter under the hood!
Luke your bay is in need of a touch up in silver but not black!
Your bay is ready for you to come clean & paint & fit x member.
More bits you will need:
Degresser, cheap dunny brush with longest handle possible
LCA bushes (yours are stuffed)
LCA holes for sway bar are stretched & needs washer welded to it
2x ball joints
Sway bar bushes (yours are stuffed)
Radius rod bushes (yours are stuffed)
Rack boots (yours are stuffed)
I took your front shocks apart & OMG they had the nylock nuts upside down that held the kyb in & 1 of the threads is destroed, & a heap of bits where missing from the top caps! Broken sway bar mount, cut springs & all the missing bits, it would have been lovley to drive NOT!
2x ball joints
- RannerZ
- swampdonkyy
- Name: Brad
This motor is fu**ing HUGE
like OMG not, not, small! makes the ca look tiny!
The bay is clean as possible & ready for rust profing & then painting!
At least you got good leads with it! Well, three out of four is pretty good... The red ultra leads are ideal, try and find a 4th one.
<a href="http://www.s12silvia.com/community/inde ... topic=1525" target="_blank">Project12</a> WRITTEN OFF 1/1/2010 <a href=http://www.s12silvia.com/community/inde ... topic=5419 target="_blank">Notchy Turbo!</a> CA18DET 160rwkw+<a href=http://www.s12silvia.com/community/inde ... topic=5419 target="_blank">S13 Daily Drifter!</a> CA18DE, locked low Toyo R1R Bride Vios 3 Low Max Greddy Coilovers solid everything
- RannerZ
After picking up the motor and gearbox up, Matt and I went and saw Kojiro at JIS and got the last of the things needed for suspension setup.
Still a couple of things needed to make it 100%
FJ20 YO!-
Thread cleaned. If I have to delete 16 pages of sh** from a thread again, especially this one, bans will result.
