Page 29 of 34
Rannerz presents: The G-Zelly
Posted: Thu Aug 13, 2009 6:39 pm
by RannerZ
heaps good!
I know I havent ben the greatest owner and mega interested in this project as of late.
But I would have liked to help put it in.
ohwell. Cheers guys
Also. Im going to be returning the bluebird to the dealership I got it from, But I want to remove the brakes and put the drums in before I do so.
Free brake upgrade!
Posted: Fri Aug 14, 2009 10:58 am
by swampdonkyy
RannerZ wrote:heaps good!
ohwell. Cheers guys
Free brake upgrade!
I have put a lot of my time & labour into this project & I have had to research a lot of stuff that you could have done.
You havent been down in three weeks to do anything on your car at all, so the fj is half bolted in & the gear box mount seems to be wrong so the g/box is being supported by the hand brake lever for the moment ;) & I had to cut the tunnel because the g/box is longer & sits heaps higher, I think Matt s has some photos of the carnage......
So now the motor is in you & all your m8's will be able to finish it off at the rents place ;) , I'll still give you help with finishing it if you need it.
There is still heaps to do & heaps more $$$$ to be spent on this car to get it to run, like turbo dump pipe & zorst, custom tail shaft & maybe g/box mount, oil + oil filter, fuel filter & fuel hose & fuel pump & surge tank + clamps, inlet piping between turbo & afm, dizzy, radiator & fans, wiring of the motor, fuel pumps, fans, is needed just to start it!
Posted: Fri Aug 14, 2009 12:46 pm
by JACKHAMMER
nah we aint touching it, its your issue brad
Posted: Fri Aug 14, 2009 6:25 pm
by RannerZ
its hard to do a 35 min drive when I got no ride
Posted: Fri Aug 14, 2009 10:38 pm
by Joshyouwah
sigh...
should have just stuck with the ca..
ca20 that is
Posted: Sat Aug 15, 2009 6:34 pm
by swampdonkyy
FJ fitment, lol ;) ;) Image
I took photos earlyer but my phone is fu**ing up & took more just b4 dark, can see here I started with tin snips but had to get out the grinder & then use vise grips to make the gear box fit.
Posted: Sun Aug 16, 2009 12:37 am
by suraido
Posted: Sun Aug 16, 2009 9:21 am
by swampdonkyy
S12 FJ20 YO!
The FJ G/box is sitting on the old ca20 x member with half of Lukes old mount that was broken & a block of wood 4 now, I had to put the x member on with only 2 bolts, the 2 front holes in the mount into the 2 back holes of the car (if u know what I meen), the gear box is sitting heaps further back & heaps higher & a little to the right for now.ImageImage
& it did rain last night filling up the spark plug wells ;)
Posted: Sun Aug 16, 2009 9:34 am
by suraido
Haha loves the rain collecting in the spark plug wells.
Was that the ca or fj gearbox member?
Posted: Sun Aug 16, 2009 9:48 am
by swampdonkyy
suraido wrote:Haha loves the rain collecting in the spark plug wells.
Same, same & no different!
