Rannerz presents: The G-Zelly
- RannerZ
heaps good!
I know I havent ben the greatest owner and mega interested in this project as of late.
But I would have liked to help put it in.
ohwell. Cheers guys
Also. Im going to be returning the bluebird to the dealership I got it from, But I want to remove the brakes and put the drums in before I do so.
Free brake upgrade!
ohwell. Cheers guys
Free brake upgrade!
FJ20 YO!- swampdonkyy
- Name: Brad
- Car: S12 SILVIA FISCO
RannerZ wrote:heaps good!
ohwell. Cheers guys
Free brake upgrade!
I have put a lot of my time & labour into this project & I have had to research a lot of stuff that you could have done.
You havent been down in three weeks to do anything on your car at all, so the fj is half bolted in & the gear box mount seems to be wrong so the g/box is being supported by the hand brake lever for the moment
So now the motor is in you & all your m8's will be able to finish it off at the rents place
There is still heaps to do & heaps more $$$$ to be spent on this car to get it to run, like turbo dump pipe & zorst, custom tail shaft & maybe g/box mount, oil + oil filter, fuel filter & fuel hose & fuel pump & surge tank + clamps, inlet piping between turbo & afm, dizzy, radiator & fans, wiring of the motor, fuel pumps, fans, is needed just to start it!
JACKHAMMER
nah we aint touching it, its your issue brad
- RannerZ
Joshyouwah
sigh...
should have just stuck with the ca..
ca20 that is
ca20 that is
- swampdonkyy
- Name: Brad
FJ fitment, lol
I took photos earlyer but my phone is fu**ing up & took more just b4 dark, can see here I started with tin snips but had to get out the grinder & then use vise grips to make the gear box fit.
- suraido
- swampdonkyy
- Name: Brad
S12 FJ20 YO!
The FJ G/box is sitting on the old ca20 x member with half of Lukes old mount that was broken & a block of wood 4 now, I had to put the x member on with only 2 bolts, the 2 front holes in the mount into the 2 back holes of the car (if u know what I meen), the gear box is sitting heaps further back & heaps higher & a little to the right for now.
& it did rain last night filling up the spark plug wells
- suraido
Haha loves the rain collecting in the spark plug wells.
Was that the ca or fj gearbox member?
RIP CA18DET Drift project, Cube sold, S13.5 in bits, S13 still alive.
- swampdonkyy
- Name: Brad
suraido wrote:Haha loves the rain collecting in the spark plug wells.
Same, same & no different!
