- Candellan
- Name: Candellan
- Car: Nissan Gazelle
More footage of Lakeside (turn the sound down as it's bloody anoying):
Lakeside 2/8/09 Session 1 (boost leak)
Lakeside 2/8/09 Session 2 (hose clamp failed)
This time I had a major leak just before the intercooler where a clamp failed. I had been using grub screw clamps but not I've just picked up some quality T clamps to cure the problem.
RPJS12 Gazelle - "Big Block" CA20DET
- Candellan
- Name: Candellan
Back to Lakeside again & this time it's a blown gearbox....yeah!! - Lakeside 30/9/09 Session 2
Dave
No good Roger!! Vid was sweet as usual, how do u plan to replace the FJ box, or will you repair since the rest of it should be ok?
<a href="http://www.s12silvia.com/community/inde ... topic=1525" target="_blank">Project12</a> WRITTEN OFF 1/1/2010 <a href=http://www.s12silvia.com/community/inde ... topic=5419 target="_blank">Notchy Turbo!</a> CA18DET 160rwkw+<a href=http://www.s12silvia.com/community/inde ... topic=5419 target="_blank">S13 Daily Drifter!</a> CA18DE, locked low Toyo R1R Bride Vios 3 Low Max Greddy Coilovers solid everything
- Candellan
- Name: Candellan
I'll see when I get it out but I'm trying to chase up a spare regardless. I do have an SR20 box & pinny box so I can mix & match them to get it in, but then I then need an S13 front tailshaft, balance that, mod the gearbox mount, cut the tunnel & it'll have different ratios.
Not worrying about that right now cause I'm off to the WRC tomorrow....YEAH!!!!! GO Leob/Elena!!
- Candellan
- Name: Candellan
Update: The box problem turned out to be 5th gear. I've stripped 10+ teeth right off the gear so i'm guessing a crack formed & she went bang. New FJ20 box went in with a bit of effort (did it on my own).
Videos of last Sunday below. We had a dust storm the previous night & the track was very slippery so that combined with heavy rear springs meant I was sliding all over the place.
All 3 videos are from chase cars:
http://www.youtube.com/watch?v=xyiO1Bug_lc
http://www.youtube.com/watch?v=ET_KitGJo1w
http://www.youtube.com/watch?v=nWM6Gj2P3AY
- Name: James
- Car: Nissan Gazelle RS-X
still seems to stick to the track really well
what sort of speed are you carrying onto the main straight? and what do you hit before you've gotta back off for the first bend?
- Candellan
- Name: Candellan
The spedo broke a while ago but based on the dyno kph when I'm changing into 5th after 6000rpm I'm hitting 210. So by the time I'm going thorough the kink it'll be ~220kph & I'm still on 80-100% throttle there until the braking for Karosel.
I've just put the HZ springs in with the S13 rear coil shocks & they fit perfectly. I could do with a slightly higher spring rate so I might buy a set of Kings raised rear coils.
Dave
Coilovers, in the rear, with HZ (more details?) springs? how so!
- Candellan
- Name: Candellan
Sorry I thought they were HZ, but it seems they were compressed Gazelle springs - http://www.aus12.org/index.php?showtopic=1027&hl=spring
Morgy had them in the back of his Stoogemobile that I wrecked with stupidly low shocks. I have seperated S13 coilovers (ie the coilover without the spring) & welded a 3" tube to the top shock mount to drop the ride height. I'll try to get some pics as it looks really good (welding was done by GT Auto Garage). We're going to add some tubing to stiffen the rear end & one day I'll get a Bond cage in there.
Dave
Yeah all makes sense now, nice work. I'd be running some better springs though?? And i believe morgish's old shocks where EL falcon spec.
Interested in seeing your extended shock tower, but i know what its going to look like
