Quite possibly if yuo had the machining tools and patience. Your biggest problem is the oil pump. It's smaller than the CA18DET item, and wasting all that nice oil pressure on cooling pistons is going to cause surges and spun bearings. I believe this may be the big problem with the CA18DETs love of lunching big end bearings.gerryb wrote:I've never seen inside a ca18det block, is there anyway to do a mod to transfer the oil squirters ?
- Candellan
- Name: Candellan
- Car: Nissan Gazelle
RPJS12 Gazelle - "Big Block" CA20DET
- Name: Dean
Nah, their problem is pumping too much oil up into the head, and starving the pick-up.
Only way to fix it, is to fit a smaller block-to-head oil feed restrictor, and fit an external drain back to the sump on the rear of the exhaust side of the head. Mind you, this is really only necessary for CAs that cop a beating frequently. Nismo oil pumps are just a waste of money because of this.
Stock motors will get away with frequent oil and filter changes (Always do both), just to keep the whole lubrication system nice and clean, to aid drain-back.
Can do cash jobs!Sadistic Moocow - MSN wrote:im usually naked anywayclothes are for rich ppl
- Candellan
- Name: Candellan
Long overdue update:
My Big Block powered Gaz has finally been booked into get it's engineering cert and will be registered next week!!
Beware SEQld, the CA20DET will be terrorising a street near you soon.....
morgish
I'm hot on your arse Candellan.
Show you that Displacement isn't a replacement.
Trying to drift an open-centre diff is alot like masturbation, it's alot of hard work, it's not acceptable in public, if you do it too often you deserve to go blind and in the end you're only f--king yourself.
- Vlad
- Name: Vladimir
- Car: JZX90 Chaser
nice!! well i beat you, mines on the road already
haha but its only a rebuilt ca20e
but you have your license and i dont
Subliminal Message Inside..dorigazu power.. IGNITION DVD FAIL says:when it rains i cant demistso i drive with windows down and a towelplease think of me lol
xr655
Umai is correct as usual. Can i tell you that the age old myth of "must have high oil preasure" is all crap and does bugger all to help your engine life. Its all about temperature constant preasure and supply which means getting it back to the sump after its done its job. Reputable Race engine builders look for around 40psi and believe thinner is better and thats where they gain power on the engine dyno. Thicker oil under and more preasure = power loss on an engine dyno.
- Name: Dean
Haha, yeah. Can you tell I spend too much time with my head in books?
High oil pressure is totally unnecessary. You're spot on there, Ralph.
All the best with getting the cert, Roger. Hopefully they will be fair, and lenient
PSI-S12
sounds like kris is getting his shit together too. that makes 3 of us...
should be good. 3 loud gazelles terrorising stuff. thats the shit i dream about...
mmm...
mmm...
Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car.Horsepower is how fast you hit the wall, torque is how far you take the wall with you.CA18DET+FJ20E S12'S - OH HOW I MISS THEE...SR20DET S13 SILVIA - FOREVER UNDER CONSTRUCTIONNEED WHEELS REPAIRED? 0419 763 226 - WILLNEED S12 OR IMPORT RELATED AFTERMARKET PARTS? 0419 763 226 - WILL
Ozchuck
Ahem...
Have you not seen my profile?
I'm offended (jk)
I'm offended (jk)
MATTHEW - S12 Gazelle - THE NISSAN KE70!S12GAZELLE.COM - AUS12.ORG - CLUB-S12.ORG <- Lets all forget our troubles with a big bowl of strawberry icecream- Candellan
- Name: Candellan
Well the big block is pretty much ready for the road. Just an electrical gremlin stopping the works. The rebuilt alternator (which had been proven to work 100%) won't charge. Should abe a 5 min thing to fix for our uber zappy. So this week for sure it's on-the-fookin-road!!
