Tomei & Mines ECUs - Would you?
No replies to this topic
#1 SFort
SFort
  • 120 posts
  • Name:Mitch
  • Car:S14A & S12
Posted 22 January 2013 - 02:10 PM
Hey 12ers,
I've seen a very cheap Tomei ECU which I am thinking of throwing in the track car. Has anyone got good or bad stories to tell? I would normally avoid these things, but it could be a while until its tuned and removing the speed cut would be nice.
It's a CA18DET, T28, cooler, exhaust and fuel pump. The rest is stock at the moment.
Tomei's website says:
1、Eliminate top speed limiter
2、Shift rev limiter timing
3、Eliminate boost limiter
4、Modification of fuel correction map and Ignition map
5、Change quorum (k)
6、Change lattice of the map (RPM, injection time)
7、Modify every correction points
Cheers!
