Indicators flasher can location?
2 replies to this topic
#1 james
Posted 27 November 2011 - 05:44 PM
I'm sure this has been asked before, but I can't find it and I'm not near my car or factory manual..
Where is the flasher can located for the Nissan gazelle?
From memory it's up under the driver's side of the dash near some relays, but I'd like to confirm it or even a photo of possible. My mate can't find his and it's busted.
Help appreciated! Thanks guys!
(just to confirm, looking for the little solenoid, relay, thing that makes the lights FLASH off & on)
#2 CitizenErased
CitizenErased
  • 108 posts
Posted 29 November 2011 - 11:19 PM
Yeah mate, its up under the dash on drivers side. Can't remember if it's supposed to be mounted to anything, mine was just sitting amongst the wires when I changed it a while ago.
#3 blacky05
  • 699 posts
Posted 02 January 2012 - 10:09 PM
This is probably too late, but I went through this last night on my daily. The flasher had been replaced and was hanging down. Typically it is a square relay looking thing that has a clip that should clip onto a piece of metal along the steering column. The stock ones have three pins, but you can replace them with flashers that only have 2 pins. You just plug it in the right way so that the earth (I'm guessing?) doesn't get used on the factory plug.
