speedo stopped workin
12 replies to this topic
#1 robert
robert
  • 304 posts
Posted 12 October 2010 - 08:16 PM
hey was drivin home tonight and my speedo just stopped,
is there any quick fixes?
or is it full speedo cable i have one in my other shell if i need it
and ye how do you generally change em never had to do one before
Theres no point building a car just to look at it. If your lucky to drive it once a month may aswell burn it.
Posted 12 October 2010 - 08:57 PM
Sounds like the cable has crapped out.
Bare in mind auto and manual cables are different, as the speedo drive in the gearbox isn't the same.
#3 snafu
snafu
  • 50 posts
Posted 12 October 2010 - 09:44 PM
Mine stopped a couple days ago too. I'm assuming the flimsy white piece of plastic on the speedo end has cracked.. again.
Not hard to change really.
Remove the cluster. Push the cable to the left out of its slot.
Undo 3? bolts on the firewall holding a plate with the cable coming out, below the clutch master.
Unscrew cable from gearbox drive.
Do those in whatever order you want then pull the cable through the engine side of the firewall.
#4 EightySix200sx
EightySix200sx
  • 313 posts
Posted 13 October 2010 - 01:46 PM
ah i assume its a analog cluster eh?
if digital you will have to source a new control unit for the cluster that seems to always be the culprit
Posted Image= low fun sexytime! -low.XII.position =Need S12 Parts? Vinyls? Whatever! email: lowXIIposition@yahoo.com-Tijuana makes me happy -Demi Lovato makes me happy -Latinas make me happy period!
#5 Umai Naa!!
Posted 13 October 2010 - 06:00 PM
We never got the digital clusters here. Only Matty's old green RX-G (which now belongs to Roger) has one as far as I know.
#6 EightySix200sx
EightySix200sx
  • 313 posts
Posted 17 November 2010 - 03:35 PM
no kidding! usually its the cable on analog clusters that goes bad,
#7 blacky05
  • 699 posts
Posted 28 November 2010 - 06:53 PM
I have the same problem although slightly more complex... I had to change the gearbox recently (sr20det gearbox) and used the analogue speedo sensor where the s13 digital one had been in the gearbox. It worked for about 200km's then crapped out and I had to drive behind a truck the whole way home to ensure I didn't speed lol. Anyway, is there an easy way to convert it to digital? I will check the speedo sensor spindle as I have a feeling i might have put it in backwards and it has just been stripped, so if I can just change the spindel it will hopefully fix it. Is that right? Cheers.
#8 Candellan
Posted 29 November 2010 - 06:47 AM
I'm looking into using an S13 electronic sensor & an Apexi RSM (because I happen to have one). Matty had it working with the RXG electronic dash so I can't see it being a problem to use the S13 sensor.
#9 jimmyjams
jimmyjams
  • 108 posts
Posted 29 November 2010 - 08:24 AM
Nissan electronic speedo senders send a AC signal to the cluster and use a three wire system, usually red and green ( AC signal ) and black ( groung referance) the colours may differ from other models. So if you can find the pin outs on your digital cluster ( needle or electronic type) then it should work, only problem I can see is matching your speedo sender gearing with your final drive ratio.
85 S12 Gazelle IRS FJ20et94 180SX Strawberry face SR20DET 270.5kw
#10 blacky05
  • 699 posts
Posted 18 December 2010 - 12:35 PM
But if my dash is an analogue cluster what can I do? I pulled the manual speedo drive out and it had seized, so for the time being I have put the digital the gearbox came with back in basically as a plug. Should I just get another mechanical speedo drive from a gazelle and put it in? Cause I'm a little confused about getting the digital one working... Does a mechanical speedo drive convert to an electronic signal at some stage or does it plug straight into the speedo as a cable?
#11 james
Posted 18 December 2010 - 01:27 PM
I would presume it converts to digital at the back of the dash.
Just grab another mechanical one from a wreckers, but make sure the cog is the same colour (or swap them!)
#12 Candellan
Posted 18 December 2010 - 06:32 PM
With the digital dash there's a cable that runs to a sensor below the brake master. It's not like the S13 setup which bolts the sensor directly to the box.
#13 gerryb
Posted 18 December 2010 - 08:44 PM
In direct answer to your question, yes get a new mechanical speedo drive for you g/box from an s12, (probably R31 Pintara and 910 bluebird manual ones would do just as well from memory).
Also if your speedo cable is stuffed I have a good spare if you need it.
Edited by gerryb, 18 December 2010 - 08:45 PM.
