clutch adjust
12 replies to this topic
#1 Mr.CA
Posted 14 September 2009 - 07:16 PM
hey guys got a quick question, drove the rsx 2day and the clutch needs adjusting on the pedal heaps!
I looked at it and there seems to be a threaded rod the goes onto the pedal with just one nut on the rod,
so u losen the nut but how the hell do i spin the rod 2 adjust the clutch grap point?? also cause i know someone will
ask the pedal is at its max out so i have heaps of room to play with. and the clutch is like 5months old.
any help would be great as the clutch is grabing like 5mm off the floor, make it a bitch to drive at the lights haha
cheers,mike
#2 swampdonkyy
  • 1,134 posts
Posted 14 September 2009 - 07:26 PM
cheers,mike
It sounds like your clutch master or slave cylinder is dieing
checked your clutch oil level lately?
Edited by swampdonkyy, 14 September 2009 - 07:27 PM.
#3 Mr.CA
Posted 14 September 2009 - 07:47 PM
for the ppl playing at home brad once again saves the day, pedal just need a adjustment.:) happy days
cheers,mike
#4 swampdonkyy
  • 1,134 posts
Posted 14 September 2009 - 08:27 PM
Here's how to ajust your clutch pedal
You will need to remove the split pin or clip 2 remove the pivit bolt that holds the clutch pedal to the master cylinder shaft.
Now you will you have to undo the ajustment bolt, so you have full swing in the pedal
Now you should be able to swing the shaft off of the pedal
The shaft has a 6mm flat spot for a spanner or you can just use vice grips to hold the shaft wile you undo the 12mm lock nut
To ajust this in the car is a real back breaking job & I recomend you take out your front seat.
Edited by swampdonkyy, 14 September 2009 - 08:28 PM.
#5 Fury-S12
Posted 14 September 2009 - 11:07 PM
just to help those playing at home and to stop issues moving the nut which way adjusts the grab point lets say away from the floor (its probly the obvious way but hey)
#6 castle
Posted 03 October 2009 - 10:37 AM
Just did this task thismorning. Not the easiest thing to do with a full dash and drivers seat still in, but it can be done with some determination. A very fiddly job to get right to the top of the clutch pedal, I used a set of pointy nosed pliers to align the nut and pin when putting it all back in. Getting the bolt back in was by far the most annoying part, swearing at this stage helped alot. I also recommend not going to extreme with winding the nut in or out, as only a few turns in or out has a surprising effect on adjusting the pedal.
Cam, it's as it seems. Bring the adjuster out to bring the pedals bite out more from the firewall. Wind in to go closer.
Cheers for the pics and descriptions Brad, made it alot easier.
Matty.
#7 Umai Naa!!
Posted 03 October 2009 - 12:02 PM
It's actually meant to take up MOST (not ALL) of the freeplay between the pedal and the hydraulic actuation in the master cylinder.
#8 Bee Jay
Bee Jay
  • 39 posts
  • Name:Brette J. Beran
  • Car:'85 Gaz, 88 Be-1
Posted 22 February 2012 - 12:49 PM
My car just came back from roadworthy and one of the minor stuff that needs fixing is the clutch pedal. The actual pedal is further back than the brake & accelerator pedal. So if I was to adjust that nut will it pull my pedal back into position or just change the catching point?
Want to be sure because I know this will be such a pain to do.
Edited by Bee Jay, 22 February 2012 - 12:50 PM.
My cars: '85 Gazelle, '87 Nissan Be-1 (In-Progress)
My motorcycles: '11 Suzuki TU250X
'Can't believe my Gaz hasn't broke down yet...'
#9 S12NUT
S12NUT
  • 391 posts
Posted 22 February 2012 - 01:21 PM
The gold bolt to the right of the pedal adjusts the height of the pedal
#10 Bee Jay
Bee Jay
  • 39 posts
Posted 22 February 2012 - 01:47 PM
Ok thanks for letting me know.
Edited by Bee Jay, 22 February 2012 - 01:47 PM.
#11 james
  • 2,296 posts
Posted 22 February 2012 - 04:46 PM
I'm amazed that you'd fail roadworthy for that!? My accelerator is always lower than my brake and clutch.. and clutch position is personal preference..
Easy to fix for roady and then adjust it back though ;)
7 years and 7 S12s on... still going
#12 inmans12
inmans12
  • 428 posts
Posted 22 February 2012 - 07:16 PM
Hate it when they dont pass you for stupid stuff like that, we had to go back for pedel covers! Waste of fuel and time.
Assorted S12 parts for sale! PM For Enquires!
#13 Bee Jay
Bee Jay
  • 39 posts
Posted 22 February 2012 - 07:17 PM
Yeah some of the stuff it failed on was just plain silly. Better to be safe when pulled over then be fined for something stupid like that.
