dash lights and the things they reprsent
8 replies to this topic
#1 Fury-S12
Posted 13 July 2009 - 02:20 PM
this is probably a stupid question but are the dash lights and the things they represent linked at all, in more detail the dash light for the rear defogger are they in the same circuit as the actual defogger.
i ask because wen i got my 12 the rear defogger bit that connects glass to wiring was cut the fuses removed and the dash light didnt work so i replaced the fuses re soldered the wires and tried it out but it still doesnt work and neither does the dash light so im wondering if they are the one linked problem or 2 separate ones to eliminate where to look
#2 Cheddle
Cheddle
  • 144 posts
Posted 27 August 2009 - 10:08 AM
id assume its the one problem. the demister should work even if the blub is blown..
- S12 notch SGL-x - CA18DET REBUILT w/ 160 RWKW @14 PSI - coil-overs front+ falcon/commo rear - $5,000!!! 0407815680
#3 gadget1382
Posted 27 August 2009 - 12:52 PM
Id' check the earth and make sure the switch works.
#4 Fury-S12
Posted 27 August 2009 - 07:35 PM
ah didnt think of the switch itself all the other ones near by work tho
#5 Cheddle
Cheddle
  • 144 posts
Posted 28 August 2009 - 03:40 PM
do you have the "timer" switch that leaves the de-fogger on for a set time and then turns it off autmoatically??
if so it really could be quite a few things casuing you greif
if you cant figure it out then re-wire it. add a different switch in its palace. maybe one of the headlight popper ones (on-off) and run your own relay and trigger...
have you tried using some epic anti-fog stuff?
#6 Fury-S12
Posted 28 August 2009 - 06:54 PM
na man only got the GL pov pack so no timer just on or off
never tried the anti fog stuff never heard of it being good or not , you vouch for it?
#7 Cheddle
Cheddle
  • 144 posts
Posted 24 October 2009 - 01:26 PM
i have some epic anti fog that i still have not used... im lazy... but yeah apparently its great stuff, you have to apply it correctly tho, just follow the instructions EXACTLY... as some you leave on, some you wipe off, some you clean off... and if you dont do it propperly it can leave crappy milky residue thats worse than fog all over your windows...
#8 Fury-S12
Posted 28 October 2009 - 11:49 AM
i finally got some and applied it and of course there hasnt been a time where the windows would fog since lol
#9 Cheddle
Cheddle
  • 144 posts
Posted 31 October 2009 - 09:40 AM
lol, mine are super-foggy... i blew my heater core with the heater on full blast... and its left coolant residue crap on my windows... ive tried to clean it off but it must still be there becaues i fogs up really easy... like seriously... if i breath too heavy with my windows up it will fog up...
im way to lazy to use my anti-fog stuff yet tho lol... might do it tonight!
let me know how u go when it actually does get cold enough to fog up! maybe take the missus for a "parking" session and see if they fog up?? lol
