electrical problems no power till I rev
5 replies to this topic
#1 swampdonkyy
Posted 07 December 2008 - 05:39 PM
OK well I've just bought my 2nd s12 & put in new fuel tank & fitted r31 front brakes & replaced bent control arm. Then went on to the electrical side. I put new battery in fixed everything else turned the key & it started, "wow" but nothing electrical works (lights, windows, dash, clock, warning lights, interior lights, lighter, antenna, radio or the fan) until I rev it! Then everything works. As soon as I turn off the motor & turn on acc nothing works (lights, windows, dash, ext), I need to start the car & rev it to close windows & have to re tune the radio every time. WHATS WRONG with my car? & How do I fix it?
Edited by swampdonkyy, 07 December 2008 - 05:41 PM.
Posted 07 December 2008 - 05:55 PM
what does the dash's voltage say when it's off and running? should be 12V and 14.4V respectively.
#3 Pistonfreak
Posted 07 December 2008 - 06:08 PM
Check the plug on the back of the altinator is plugged in properly
when you turn your ignition on, the battery symbol should be lit up and go out when engine is running.
sounds like your reving it to exite the altinator into chargeing
#4 Darryn
  • 1,176 posts
Posted 07 December 2008 - 09:44 PM
i bet 50 bucks Black fuseable link... pop the cap of the little box infront of the battery... i bet the link is farked... sooo common with these bloody cars. replace the link with a known good one and should fix it.
does all electrics stop again when lights are turned on or you use the brakes??
#5 swampdonkyy
Posted 09 December 2008 - 08:50 AM
"you were right" dam fuseable links
all fixed :) thanks for your help, stopped me from havin to use my brain!
cheers!
#6 Darryn
  • 1,176 posts
Posted 09 December 2008 - 08:57 AM
haha, no worries. Yea their sh**. Been probems with the links in both my s12 i have had on the road.
