shut down problem
7 replies to this topic
#1 Mr.CA
Posted 18 October 2008 - 02:04 PM
hey all
car is starting to give me the shits when i turn it off it take a while to turn off after i turn the key to "off"
and them sometime it just turns of straight away and other ages and shuts down very slow.
anyone got any idear on what it could be? or have had this problem?
i was thinkinf of pull the cover off around the steering wheel to check conection??
cheers,mike
Posted 18 October 2008 - 06:56 PM
my mate's CA20 pinny does this too occasionally and we have no idea why either!
let me know if you find a cause :mario:
#3 Fury-S12
Posted 19 October 2008 - 03:30 PM
mums nubirs used to do this to but it was auto and it tuned out the be the ecu that was buggered
id say checking the connection etc in the column would be a good start tho
#4 gadget1382
Posted 20 October 2008 - 09:57 AM
Mine was my thermo fans. The fan relay caused current to run through the permanent "on" to the switched "ignition" so not until the temp dropped. So essentually a turbo timer that opperated on the temp of the radiator. Just a pain when your needing to be quick on a hot day. :thumbsup_anim:
#5 Mr.CA
Posted 23 December 2008 - 01:34 PM
well i finaly have the car back so im back try`n tox this prob
now i have no idear really when it comes to elec stuff lol but i reckon i hvae found the prob,
the ecu still gets power after i turn the car off , and thats why it still runs.but of late i have had 2 stall it because it just wont turn off
i have this wiring map here and i have put a test light on the ING saw (S1) and (:suicide_anim: they still has power after the key its turned off
so that would be why the car still runs, ok but what do i do from here?? how do i fix the prob?
help please lol
cheers,mike
#6 Lister
Posted 23 December 2008 - 01:51 PM
The power source your feeding into the ecu is obviously not a switching power source. Find the power or "A" power source that is only on whilst the key is on....If you think you have already got that, what you need to find is where is getting alternate power from via a back feed, Possibly injector wiring or coil wiring, both of these have 12v feeds into them and are earth switched via the ECU................
#7 gadget1382
Posted 23 December 2008 - 02:18 PM
Alarms are known to do it along with dodgy radio installs. If you have either, may want to check that too.
#8 Mr.CA
Posted 24 December 2008 - 10:05 AM
well with my lack of elec skills, i worked it out they had run the (ING saw) into the old one for the stock
ecu so i just cut it off and run it straight to the same wire as my stereo under the barrel, and it now turnes off! yay
thanks guys
mike.
Edited by Mr.CA, 24 December 2008 - 10:07 AM.
