Fuelguage
16 replies to this topic
#1 DRIFTKID
DRIFTKID
  • 670 posts
Posted 15 September 2008 - 02:16 AM
Ok i think i broke it now when i fill up it only goes to 3/4.. any help :S
RIP GAZELLEBuy my parts!!!
Posted 15 September 2008 - 09:08 AM
Pull it out of the tank, plug it in.
With the ignition on, move the float up and down, and see what the gauge does.
If it doesn't read up to the full mark, you have a dud sender.
If it can read up to the full mark, then you need to bend the float arm down a little bit.
#3 DRIFTKID
DRIFTKID
  • 670 posts
Posted 15 September 2008 - 09:28 AM
fu** gay..
pulng that thing out is probably the most frustrating thing to do on the car!
#4 Umai Naa!!
Posted 15 September 2008 - 09:35 AM
It's like a 10min job :(
#5 DRIFTKID
DRIFTKID
  • 670 posts
Posted 15 September 2008 - 09:46 AM
yeha i didnt say it was long
but its 10 minutes of swearing!!
#6 gadget1382
Posted 15 September 2008 - 11:04 AM
Dont forget cut's and fuel sting!
:P
Mine i thought was faulty until i filled up at a bouser that didnt turn off... overflowed the tank and then it read over full :(
#7 DRIFTKID
DRIFTKID
  • 670 posts
Posted 15 September 2008 - 01:55 PM
i always over fill till petrol is at filler neck.. still reads 3/4 lol bastard of a thing..
#8 S12 GAZELLE
S12 GAZELLE
  • 96 posts
Posted 15 September 2008 - 02:49 PM
mine does the same thing i fill it to the top then till it over flows and it still only reads 3/4 full :(
#9 Dave
Posted 15 September 2008 - 03:06 PM
Same as above, but it reads correctly when the car is turned off :S
#10 Umai Naa!!
Posted 15 September 2008 - 08:31 PM
My Commodore's one reads nothing until you smack the side of the cluster. Then it springs into life :D
Ahh... the joys of owning an Aussie car :ph34r:
#11 Fury-S12
Posted 15 September 2008 - 09:15 PM
must be an s12 thing or just an old car thing coz mine does the same thing lol
#12 gadget1382
Posted 16 September 2008 - 09:05 AM
Old nissan thing... Datto's and Bluebirds have the same issue :ph34r:
#13 james
Posted 17 September 2008 - 08:51 AM
mine reads full correctly
but it will do 300km sitting on half a tank before it suddenly drops to 1/4 tank.
i've given up and just read the odo if i want to know how much is left
#14 Fury-S12
Posted 17 September 2008 - 11:46 AM
mine used to do that too but we i changed my dash it fixed it lol
#15 james
Posted 18 September 2008 - 12:12 AM
so your suggested solution is a complete swap of the components?
#16 Fury-S12
Posted 18 September 2008 - 08:55 AM
it worked for me but other things were broken in my dash (trip odometer) i duno if its the actual solution for the issue but it worked for me so if ya can get a dash cheap enough its real easy to swap em out and it if dnt fix the issue well then you have a spare dash to do watever with ;)
#17 gadget1382
Posted 18 September 2008 - 10:38 AM
Earths with the dash seem to be rather fickle at the best of times... i'd re-earth it n see what happens.
