Sleepy Eyes
81 replies to this topic
#1 Fury-S12
Posted 06 October 2006 - 01:43 PM
OK as promised ill do a quick write up on how i did my sleepy eyes, im serious wen i say "easy way", you dont need to remove any panels or cut anywires
first up locate this little black box with the four colours writen on it, as you can see mines infront of the battery
then flick the cover off (this may require small japanese hands :P) revealing these four things
basically as the top of the black cover says the brown one on the end is your light plug simply pull this off (and store safely in glovebox) revealing two spade type prongs
simply wire in your switch to these two prongs, its up to you how and where you run the wire for the switch too but youll probly have to drill a whole in the black cover to get the wire out i havent tried yet :P
once you have your switch in place you can start having fun
-If your switch is ON then the pop-ups will function as normal
- to make them sleepy simply turn your switch to OFF then wen you press the button to make the lights go up nothing will happen at this point simply flick your switch and let them go up as far as you want and flick the switch again.
There ya have it easy enuf with the same results as any other way but requires no wire cutting so deem it better :P
#2 Shinigami
Shinigami
    Birthday Nugget
  • 668 posts
Posted 06 October 2006 - 06:39 PM
thanks for that :P im gonnaa try it 2moro but first things first a switch :woot:
John
** Drive It, Like You Stole It **Posted ImageTouge and Drift Lover >.
#3 al3x
  • 344 posts
  • Car:CA18DET S12 Hatch
Posted 07 October 2006 - 02:18 PM
I had this mod already done to my car when i purchased it.
Heres the vid of it working and a few pics.
#4 Guest_4GOT10_*
Guest_4GOT10_*
Posted 07 October 2006 - 05:32 PM
Nice work boys!, i want something along the lines of a volume switch tat i can play until i am happy with the exact position of the lights!
I dont like the guess work in it!, and also because i want to play with them when sitting at the lights!
Wil
#5 al3x
  • 344 posts
Posted 07 October 2006 - 06:03 PM
To adjust them up and down you'll probably have to cut into the wires on the headlight cleaning switch, as this one powers them to go up and cancels them to go down.
Ill look into the wiring a bit more and see if i can come up with a circuit that will use a pot to set the desired height up and down.
I was surpised when i found out what the swicth did, I've seen lots of cars that have random wiring changes made by the old owners....
#6 Umai Naa!!
Posted 07 October 2006 - 10:10 PM
Wil, you'll need a momentary on/off/momentary on switch.
Wire it into the wires on the cleaning switch. You only need 3 of the 4 wires. From memory, it's the light blue wire you leave out.
#7 Guest_4GOT10_*
Guest_4GOT10_*
Posted 08 October 2006 - 09:22 AM
Sick, cheers Umai, once i get the car back, it will be the first thing i look into! :)
Wil
#8 Fury-S12
Posted 08 October 2006 - 10:00 AM
haha a volume switch like a turn switch that wen you turn it they go up(or down) that be kool dunno how youd make it work tho :)
either way i took the s12 out for thre first time since i got it and boy was it fun playing with the lights lol also the car is a dream to drive
#9 Bjay
Bjay
  • 62 posts
Posted 08 October 2006 - 10:39 AM
yeah castle did this to mine (previous owner) hahaha now i nicked a engine start switch surround so it will fu** up who ever breaks in to my car mauhahahahahahaha
#10 Mr.CA
Posted 21 December 2006 - 07:51 PM
ok i know this topic is a little old but anyway here ya go
i did the sleepy eyes to day, the way i think is the easyest.
i got a Narva switch part number(63044BL) it was around $16
then take the old switch out cut all 4 wires and strip the pink,red and purple wires,
then put a female clip on each. then on the back of the new switch there are 6 points witch are number`d
1-6. conect the pink wire to the point numbered 1, the the red to the point numbered 2 and the purple to the point numbered 3. and you leave the blue wire out.
then there you have it Sleepy eyes!! the longer you hold the switch down the more they go up etc..
mike
Edited by Mr.CA, 21 December 2006 - 07:52 PM.
#11 Fury-S12
Posted 21 December 2006 - 08:58 PM
thats a pretty good idea its pretty much wat 4got10 wanted
#12 gadget1382
Posted 21 December 2006 - 10:08 PM
does that way still allow the lights to turn on and go up by themselves?
#13 s12silvia
s12silvia
  • 494 posts
Posted 21 December 2006 - 11:25 PM
im gonna give this a go tommorrow just for the hell of it lol also going to try and find a new place for my pod filter so there is less distance for the air to travel
#14 Pistonfreak
Posted 22 December 2006 - 08:26 AM
Wow all that work
and going from the engine bay back into the cabin too hard. lol
All I did was pop out the up/down switch in the dash then put a toggle switch (or like mine a factory looking on / off switch) on pink wire and put the new switch directy beside it in the spare position. Done
#15 Mr.CA
Posted 22 December 2006 - 12:37 PM
yeah man they still go up when ya turn the lights on even when in sleepy position,but when
ya turn the lights off you have 2 push the switch to make em go down :P
Wow all that work
yeah that way is fine but in my car i have the LED for my alarm there, and i would like to have just 1 switch
apart from 2. just 1 having looks cleaner
mike
#16 Umai Naa!!
Posted 22 December 2006 - 05:21 PM
No engine bay access required. It's all done in the car at the switch.
Two of the three S12s I own/have owned, have this mod done. When I can be arsed, I'll buy another switch, and do the pig for HA HAs.
#17 s12silvia
s12silvia
  • 494 posts
yay i now have sleepy eyes :P went to move my pod filter but im gonna have to relocate my battery in order to do so and i cant be arsed :P
#18 Fury-S12
Posted 23 December 2006 - 01:05 AM
i have a led there too but nothing is hooked up to it as far as i know (havent looked) is this standard or shld i play the follow the wire game?
#19 Mr.CA
Posted 23 December 2006 - 06:16 PM
thats good 2 hear that the info has help ppl
i dont think it is standard my car did`nt have one until i got the alarm put in ;)
mike
#20 gadget1382
Posted 24 December 2006 - 02:36 PM
Seeing as my car no longer has cruise control, would it be possible to remove that... and put in another switch there? Maybe modefy a secondary dimmer switch for the dash to control the lights movement?
Basicly which wires do what?
