Running 18psi daily... Wait, i mean volts
15 replies to this topic
#1 Dave
Posted 22 August 2008 - 04:23 PM
Problem: Alternator is buggered I believe, or perhaps the dash but i doubt that. More revs means more volts on the dash, will check with multimeter tomorrow i imagine. Its basically the same relationship wether freerevving or under load, idle = 14 drive = 16 flog = 18 or more according to the dash. Ive been driving it like this for weeks with no problems, not even my amplifier has complained.
Question: Whats the problem here, and how does one fix it and what is that likely to cost?
Cheers, Dave
#2 al3x
  • 344 posts
  • Car:CA18DET S12 Hatch
Posted 22 August 2008 - 06:12 PM
Sounds like the voltage regulator on your alternator has died, this is what keeps your battery charging at ~14v no matter what the revs.
Drop into a auto electrician and they can check it out for you.
#3 james
Posted 22 August 2008 - 07:26 PM
mine did that for a few weeks
then the alternator died completely
so i'd recommend getting it fixed :P
#4 al3x
  • 344 posts
Posted 23 August 2008 - 12:16 AM
I've got an excellent condition alternator off my ca20e if your interested? will sell it for $100 posted, would have been used about 3-4 months before taking the engine out going ca18det. let me know.
#5 Dave
Posted 23 August 2008 - 01:42 PM
Attacked with the multimeter today, dash doesnt lie, it is indeed charging at anywhere from 14 at 1000 to 18 at 3-4, and I assume it goes higher when im giving it some berries.
As an aside, would this extra voltage be the reason that in the course of a few weeks my drivers side front quarter (not the panel, the area) has all started to corrode... Like, battery acid corrode.
This car is shitting me lately, just keeps asking me to get a S13 roller...
#6 Umai Naa!!
Posted 23 August 2008 - 04:05 PM
Yeah, battery is probably venting like a bitch now.
#7 Dave
Posted 23 August 2008 - 08:31 PM
After my last post i was oh gee now it makes sense, and upon inspection my battery is cooked as, didnt see it at first glance but once i was looking for it I noticed that my battery is... well... deformed and melted and bulged on the sides, all but exploded. I blame everything on CA20Es, theyre sh**.
#8 MellettMotorSport
MellettMotorSport
  • 234 posts
Posted 29 November 2008 - 08:18 PM
Mine did the same until the battery died, then the alternator died. Happened after having the vented bonnet on , and it pretty much poured it onto the alternator, geussing just ate it out...hehe...
#9 gadget1382
Posted 18 March 2009 - 02:00 PM
Extending on an old topic.... My Regulator died last night.
I ripped the alternator out, but when quizzed by the auto-elec, I noticed a 2 pin plug wasnt being used.
Apparently that assists the Alternator regulator AND the battery issue light which triggers the alternator into working at start up... which at the moment i need to blip to get 12v+ charge rather than just start n have the car die within a few minutes running solely off the battery.
So, my question is, what plugs are used on the CA20e alternator? (series one if any differece) And that way i can work out which wires are supposed to be on (going to) that plug.
Other than the large Positive Eyelet and small earth Eyelet.
#10 gadget1382
Posted 19 March 2009 - 07:17 AM
Ok boy's Listen up.
The Two pin plug that goes into the Alternator has the two wires.
_--_
[ I I ]
Plug looks like that ^
The one on the left, goes to the bettery. But can just be looped to to the alternator (+)
The one on the right goes to the black flat pin (female) plug that is on the same bit of loom. That is the battery warning light on the dash. This will "stimulate" the alternator into working at start up and be used as a warning light if the regulator shits it's self again.
The regulator will then work a hell of alot better and more stable, therefore giving all the ECU comparitive voltages more accurately and consistantly. Better for the car all round!
#11 Fury-S12
Posted 19 March 2009 - 10:02 AM
is that for ca18 or ca20 tho?
#12 james
Posted 19 March 2009 - 06:04 PM
^should be the same for both, no?
#13 gadget1382
Posted 20 March 2009 - 10:09 AM
My car is a CA18det... but the alternator could be used on either, just by switching over the pulley.
In the 2 days driving it with those two wires hooked up has made a noticable difference in how smooth the engine runs at idle and initial start up.
#14 Fury-S12
Posted 20 March 2009 - 09:55 PM
ah so it doesnt apply to ca20's outta the box
#15 gadget1382
Posted 23 March 2009 - 07:36 AM
NUP, but with all the CA20e's that have had their alternator replaced, there would probably be a few with CA18 one's on them.
#16 Gazelle D
Gazelle D
  • 198 posts
Posted 29 March 2009 - 09:17 PM
from my experience's the ca20 alternator runs a V belt and doesn't have nissan's lovely oval plug with release clip, and the ca18 runs a 4pk ? rib belt which runs the plug.
i haven't seen any later model alternators on gazelle's and went to convert mine when my ca18et had one hanging off the side but my crank pulley had a chunk missing.
i spose i could have changed the pulley and fan, but it was easier to bolt the old girl back on.
ok i'm sidetracked, i vote for newer technology, but got slack
All my gazelle's are gone, but i have a stock S14 sunday driver.
