turbo timers
21 replies to this topic
#1 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 10 July 2008 - 07:07 PM
what one do you think is better?
i leaning towards the analogue one
over this digital one
wat do you guys rekon?
or are they both sh**?
if so what should i be looking at?
Jack
Posted ImageJealousy Is An Evil Monkey
Mr Irishizzleswizzle -: two ugly chicks make 1 hot chickMr Irishizzleswizzle -: its simple maths jack
#2 Mr.CA
Posted 10 July 2008 - 07:19 PM
jack i just have a auto with manual over ride Greedy turbo timer
its good does the job got it for like $90 or something from autobarn
they all do the same job just depends what one u like the look of better i suppose
mike
#3 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 10 July 2008 - 07:37 PM
hard to put in?
also when can i grab them shockies off ya?
the top one is 25$ an the bottom one is $10
but they are a bit far for me to go pick up, if you know wat i mean ( aka in japan)
#4 gadget1382
Posted 11 July 2008 - 08:18 AM
Rather not have one at all...
Either one, if you are going to put them in, should fit nicely into the "clock" location :P
#5 kj0
Posted 19 July 2008 - 11:50 PM
Does anyone have the wiring diagram for a TT into the gazelle?
#6 Umai Naa!!
Posted 20 July 2008 - 07:32 PM
They're pretty universal.
I think they only need a constant 12V, an ignition feed, an earth, and an illumination feed.
Get yourself a test light, and start probing. You should be able to find all theses wires behind the dash around where the radio is.
#7 gadget1382
Posted 21 July 2008 - 08:33 AM
All are easily located on the steering column. But can be found just about anywhere. The Radio has those wires, so you could nick them from there too.
#8 Candellan
Posted 21 July 2008 - 12:16 PM
I like my Apexi pencil timer. It displays battery volts (at the ECU), AFR & O2 readings as well as an auto timer or manual override. They tend to go for a bit more than 25 pesos though.
#9 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 21 July 2008 - 05:22 PM
so you think the apexi one is decent?
were abouts have you got it mounted?
#10 james
Posted 22 July 2008 - 11:38 PM
might want to look at this
How to: Turbo Timer(HKS Type-0)
courtesy of club-s12.org
#11 Candellan
Posted 23 July 2008 - 10:44 AM
Yeah I'm happy with it. Never caused any problems other than it can't be integrated with the Jaycar alarm/central locking easily so I have to wait for the timer to stop before locking the car.
I have the interface mounted below the instruments on the bit of dash between that & the steering column cover. Fits perfectly.
I believe Lister has some TT looms at will allow the whole thing to be a plug in job for a simple timer, however the Apexi one also gets a couple of signals (O2 & ground) directly from the ECU and the park brake. It's pretty simple though. Look at Apexi USA for installation instructions - http://www.apexi-usa...tallation/5.pdf
#12 Lister
Posted 23 July 2008 - 11:37 AM
Yup i have found 2 Since buying a new one for myself......Pm if you want one.........
#13 kj0
Posted 26 July 2008 - 10:10 PM
I got my unit today, and well.. All is good, but I don't have the spade plugs, What ya recon about De-Pinning it and soldering it?
#14 kj0
Posted 26 July 2008 - 10:21 PM
Well.. see the thing is, My turbo timer has 4 wires in a spade plug connection plug, and well.. It mentions e-brake in that one. However, the e-brake doesn't have optional next to it.... Maybe it's best to take a photo and see if anyone can pin point it!
#15 kj0
Posted 27 July 2008 - 12:02 AM
Stupid Edit button not being around.
anyway, I took a pick, I noticed there is a grey wire coming out of the actual Unit, a brown wire going to the control panel and a spare Yellow cable. Inside the plug is the Positive, Ground, Accessories and ignition wires.
This unit came out of an FC so yeah...
#16 gadget1382
Posted 28 July 2008 - 09:10 AM
The e-brake one is so that the car wont keep running unless the handbrake is on.
Earth it and the timer will not work, put it to 12V and it will... basicly T it into the switch on the handbrake and it'll work like it should.
#17 kj0
Posted 31 July 2008 - 07:16 PM
Don't ya just love it when you are installing something with Wires and all of a sudden you can't start your car yet cause you haven't shielded the wiring with any Electrical tape.
#18 kj0
Posted 03 August 2008 - 02:08 PM
hmm... well.. I've gotten under my dash, Does anyone know a good point to splice into the ignition? I have a massive tube coming from mine that a whole bunch of other wires join in with. So it's not the simplist way.
#19 Dave
Posted 03 August 2008 - 08:20 PM
Same place you get power for your headunit for.
#20 james
Posted 03 August 2008 - 10:29 PM
if you need power, yank out your fuse box and have a look on the back of that, live power everywhere
if you want to put in an ignition kill switch, put it on the other side of the fuse box
