How to get the Tacho working...
44 replies to this topic
#41 Fester
  • 128 posts
Posted 15 January 2007 - 07:14 PM
Contact 'Fester', he has a microtach in his s12 and has the tacho hooked up and working I think. He is quite good on electronics and the microtech, from memory there is some trick to getting the s12 tach to read accurately with a microtech that he knows, (use the member search facility to find his profile so you can pm him)
:) /me shakes head sadly at poor gerry... :orly:
As it happens my tacho isn't hooked up (it was with the old Digi, but not the MT8), but that's mostly because I'm a lazy bum. There's a bunch of other electrical stuff that's died or is on the way out, but I'm too damn lazy to fix that as well. I should take a couple of days off work and pull her apart a bit I suppose, but its so hard to find care factor :P
I'm thinking about making the trip up in 1-2 weekends kingos, I'll let you know. Always good to see another gazelle :)
#42 Lister
Posted 22 November 2007 - 08:10 PM
Sorry to raise an old thread but i wonder if some electronics wonder boy has an answer for this one. I have an RB25 neo running an EMS 8860 whats the chances of the stock tacho running on A 6 cylinder??
#43 gadget1382
Posted 23 November 2007 - 07:00 AM
might get away with using 4 diodes not 6... if you use 6 you'll have rev's another 1/3rd higher than what they actually are.
But i dont know how effective that would be.
#44 Lister
Posted 24 November 2007 - 08:08 AM
I have discovered the secret. Early import v6 Maxima's have a circuit board nearly exactly the same as the Gazelle, i will be using the board and keeping my motor and needle. As the new board is slightly larger i will run it remotely and this will also enable me to adjust the trim pot to get it as accurate as possible.
#45 DRIFTKID
DRIFTKID
  • 670 posts
Posted 07 March 2009 - 11:07 PM
where is the tacho resistor box located? anyone got apic
RIP GAZELLEBuy my parts!!!
