parkers and interior lights do not work
13 replies to this topic
#1 james
Posted 20 February 2008 - 09:22 PM
my parkers and all interior lighting does not work (dash backlight and roof light)
i've checked fuses and globes
no cables seem to be missing or loose
does anybody know if there is a common reason for this fault?
i was told loose connection at the rear lights, but can't find anything myself
could it just be something in the stalk/column?
would really like some advice before i have to do a trace...
#2 gadget1382
Posted 21 February 2008 - 06:38 AM
The stalk is your best bet after fuses and globes.
Just a matter of taking off the column surround Unplugging it and then taking the two screws holding the stalk in out and it should slide out.
There are prongs that are the "connectors" if they are bent wrong or corroded or for some other reason do not connect, your lights will not work.
Wouldnt be a bad idea to clean out and re-lubricate it while your at it anyway.
#3 james
Posted 21 February 2008 - 06:39 AM
-sigh-
alright, thanks, i'll give that a shot this afternoon
#4 gerryb
Posted 21 February 2008 - 07:48 AM
Bit confused as to exactly what's not working? Parkers and interior light seems clear enough, but also your dash lighting?
Far as I can remember the interior light and parkers are on a different circuit. Only thing I can think of is that there is a bad earth somewhere.
Did you swap the fuses with ones from good working circuits? (sometimes these blade fuses look good but are f'd)
#5 gadget1382
Posted 21 February 2008 - 08:34 AM
The parkers are still operated on the same switch / relay as the behind dash "night lights".
Its not that bad a job, takes about 30min when you dont know what your doing :P
#6 james
Posted 24 February 2008 - 11:54 AM
now have interior lights working
but rear light in hatch stays on when the hatch is closed...anybody know where the switch/sensor for this is located?
also, common problems with the indicator stalk? i have it out and the points, although worn, look like they should work
anybody recommend bending them so they get better contact? or just clean the contacts and cross my fingers?
#7 Kingos
Kingos
  • 169 posts
Posted 24 February 2008 - 12:10 PM
Just give them a good clean mate,
same thing happened to me about 3 weeks ago,
i gave mine a clean and they have been sweet since.
#8 james
Posted 24 February 2008 - 01:07 PM
well, i cleaned them...
now i've made it worse!!
my headlights are stuck up - headlights still work though
switch on dash and stalk don't make them go down...no fuses blown, so i don't know what i've done...
AND the parkers/dash-lighting still doesn't engage...
perhaps a whole new stalk is in order...anybody got one?
i think this will go off to the auto-elec tomorrow, see if they can't sort it out
#9 mats12
mats12
  • 396 posts
Posted 24 February 2008 - 03:02 PM
I used an N13 pulsar one on mine and use the dash switch for the lights
Matt______________________________________________________________________________Insert funny remark here
#10 james
Posted 24 February 2008 - 03:03 PM
yes, i think this will be my next choice if the one i get from you doesn't sort the issue
#11 james
Posted 27 February 2008 - 04:34 PM
well, it went off to the auto-electrician's today, so hopefully when i pick it up friday all my issues shall be fixed!
*fingers crossed!*
#12 gadget1382
Posted 28 February 2008 - 07:02 AM
*crosses legs, arms, fingers etc*
hope they work out what the issue is for you mate, let us know what it was once you find out.
#13 james
Posted 28 February 2008 - 03:30 PM
well, rang them just now to check on it
apparently all the wiring is fixed now, but even they cant get the indicator stalk to operate correctly
so i'll take them a working one once it arrives in the mail
cant wait to get my little thrash box back!
#14 james
Posted 07 March 2008 - 05:54 PM
well, got it all fixed up now thanks to the local auto-elec
$50 and a new indicator stalk and all my electricals are go!
took it for a thrash just now...-sigh- how i've missed that
