Dash Cluster Back light
12 replies to this topic
#1 gadget1382
Posted 23 July 2007 - 10:48 AM
Since doing my CA18det conversion and putting the dash back in, i have managed to put up with not having a back light.
But since the GF has moved to a location between a point to point speed camera check, it has become rather annoying and makes me slightly anxious driving at night... i kinda like having my points... and $$.
So i pulled the top of the dash out to access the cluster and realised that there is a globe with a black wire hanging out the back not attached to anything.
I checked the other end of the ILL wires and they seem to be earth... meaning that the 12V supply for them is that black wire.
I assume it goes somewhere near/has something to do with the dimmer, but can't for the life of me feel/see where it is.
If anyone know's where it's supposed to connect to, it'd be most appreciated.
Posted 23 July 2007 - 09:12 PM
That's the fibre optic that goes to the hole in the steering column cowel, next to the ignition lock.
#3 gadget1382
Posted 24 July 2007 - 08:20 AM
i'll pull it apart tonight n have a look.
but if you have a pic you / anyone could post of where it connects it'd be most appreciated.
Thanks dean, you really do know too much about these cars... if there is such a thing as too much knowledge :D
#4 Pedro
Pedro
  • 402 posts
Posted 24 July 2007 - 08:47 AM
Just make sure when you test it with a test light, that you also test it with the lights switch turned on.
I made that mistake when installing my stereo, the dash lights show as a negative when the lights are off.
#5 gadget1382
Posted 24 July 2007 - 09:12 AM
i used the multi-meter on it both with the lights "on" and "off" and they both came to 0v
negative light?
#6 Pedro
Pedro
  • 402 posts
Posted 24 July 2007 - 10:46 AM
negative light?
I meant shows as a earth.
#7 gadget1382
Posted 24 July 2007 - 11:02 AM
ahhh... me thinking too literally :D
#8 gadget1382
Posted 24 July 2007 - 08:38 PM
ok, had a look at and around the ignition barrel, and cannot find anything that looks like the optical connection!
Pedro, or Dean, seeing you know what it is, could you describe it in detail, or get a photo?
#9 gadget1382
Posted 25 July 2007 - 08:29 AM
Ok, after talking to dean last night on msn, i realised that, the optic cable is not my issue... Looks like i'm going back to wire tracing ;)
#10 Pistonfreak
Posted 25 July 2007 - 07:30 PM
If it's like up here
go to the wreckers
Pay $2 entry
find a gaz
then pull the dash out,
find where your wire goes
then leave.
priceless
#11 gadget1382
Posted 26 July 2007 - 08:44 AM
the thought had crossed my mind...
but we have them for $1 :thumbsup_anim:
But more than likely, i'll be in a wet cabbin as the windows and doors are often not there, or smashed :s
It must just be one plug that i havent connected...
My issue is that i have the 180 loom behind there too now so following wiring is all that more interesting. Buckets of fun! :s
#12 Umai Naa!!
Posted 26 July 2007 - 06:22 PM
Have you checked the rheostat (Dimmer)?
Also, do your parkers work? I had the glovebox light short itself out, and it took out the parkers and dash lights.
#13 gadget1382
Posted 27 July 2007 - 07:30 AM
there's voltage at the dimmer switch when i turn the lights on (it's not there when it's off)
The glove box light shorting it out? :s
Parker lights at the front of the car work.
The lights work at the shifter, the buttons for the heater control (not the backing tho) AC button... door lights all work (but thats a different circuit.
The footwell lights dont light up like they used to when the headlights are turned on too. I havent had a chance to pull the dash out again... hopefully this weekend at some point
