feul pump issues
25 replies to this topic
#1 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 14 May 2007 - 11:48 AM
my feul pump is on the blink, its temperamental as all fu**, as most mournings i have to give the tank a brutal massage to get it to start.
so i am goign to replace it, the dilema is buy a BRAND NEW ONE or get one from a wreckers?
i am kinda leaning towards the brand new one for two reasons, first of all, it is 20+ years old, so another s12 will likley have the same problems, and secondly im putting a ca18det in shortly, so to elliminate possible future fuel pump issues i was thinking of getting a aftermarket one.
can i grab ur opinions on this?
also wats a good fuel pump to get if i buy a brand new one?
and lastly how much do they generally go for?
cheers ppl!
Posted ImageJealousy Is An Evil Monkey
Mr Irishizzleswizzle -: two ugly chicks make 1 hot chickMr Irishizzleswizzle -: its simple maths jack
#2 gerryb
Posted 14 May 2007 - 12:35 PM
Yeah Jack, Get a (new) walbro intank pump,(don't touch a used fuel pump) they can be had for pretty cheap these days, I think I paid $140 or something all up for mine including postage. It was a GSS341 or 342 I think from memory. They use them as replacements in s13's etc , pretty easy to fit in the s12, in the original pump cradle in place of the original pump motor.
Edited by gerryb, 14 May 2007 - 12:36 PM.
#3 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 14 May 2007 - 12:48 PM
so i shud ask for a s13 walbro fuel pump?
does it matter if its to suit a sr or ca or will they be the same thing?
what about bosh fuel pumps, i was under the impression they are good?
i looked on egay.com
there are so many bosch pumps!!
http://search.ebay.c...PageNameZRC0023
but i couldnt see any for a s13.
i found this walbro one tho:
http://cgi.ebay.com....1QQcmdZViewItem
would they sell these at auto barn or sprint etc?
#4 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 14 May 2007 - 12:53 PM
ive also found this one
despite the ridiculous price tag, how do u rate nismo pumps?
an what are my chances of getting one tahts suitable at a reasonable price?
thanks again
#5 Nehemiah
Nehemiah
  • 379 posts
Posted 14 May 2007 - 03:06 PM
Be careful on online shops such as E-bay as many Bosh knock-offs exist.
The Walbro pumps are ment to be good for the price and install with basic tools and a soldering ion.
You can buy these kits for quite a low price and its a good upgrade over the stock pump.
To run an external pump you still need an intank pump (unless you make up a custom pickup, in wich case have fun!). So I would dich the external idea, however if you feel the need to do so at a later stage the Walbro would make a good high volume low pressure pump (im soon to be running one before my Bosh 044 external pump).
This is what you get with the kits
What you want is a Walbro 255lph high pressure fuel pump kit
Here is some info on the pump and its wiring:
http://www.kb0pax.com/s12_fuel_pump
S12 Fuel Pump Operation · KB0PAX
http://www.kb0pax.co..._wiring_diagram
s12_fuel_pump_wiring_diagram · KB0PAX
Ok... Edit:
heres a link to the pump kit on horsepowerinabox
http://www.horsepowe...ategory10_1.htm
See: Walbro 500hp in tank Fuel Pump
It retails for $195 and I have delt with these guys before (turbosmart fuel pressure regulator) and you can have the pump next day depending on your payment option. Or have a chat with your local speed shop and see what it will cost you to get one in from their suppliers . Remember if you order online you oftern have to pay postage so factor that into the total price.
Have fun!
Sam.
Edited by Nehemiah, 14 May 2007 - 03:17 PM.
#6 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 14 May 2007 - 03:27 PM
jsut went down to auto barn, they are selling 500hp walbro pumps for $169.
i was told by the sales dude, that this is a fair price. is this true?
are they hard to install? is it a case of remove replace plug in an play?
or will i have to run wires to the ecu, chassis, fuel guage, fuse box, an earth?
#7 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 14 May 2007 - 03:41 PM
just had another thought
waht bout a vl turbo fuel pump?
how well do ppl rate those?
and whats the general price range of one?
#8 Nehemiah
Nehemiah
  • 379 posts
Posted 14 May 2007 - 04:28 PM
If ya want an easy swap that is going to work use the Walbro.
The VL turbo pump is going to be harder to fit than the Walbro.
Is that a fair price? Well the site I listed wants 195$ plus postage so its up to you.
Are you planing an aftermarket comp for the CA?
#9 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 14 May 2007 - 04:34 PM
ive jsut got a stock ecu atm, will prolly stick with that an get a remap eventually
i rekon anything else will be a bit of overkill for what i want
#10 nissanman
Posted 14 May 2007 - 05:03 PM
Bosch 040 or 044.....
Honestly my mate put a WALBRO gaybo in his Rb20DET 31... not the best. theres a reason why they r soo cheap for a good rate and hp rating.
#11 = SR S13 =
= SR S13 =
  • 403 posts
Posted 14 May 2007 - 05:07 PM
040 will def be enough for your ca jack i wouldnt bother with 044 but i ahve heard nothing but good about walbro
cant judge on one stuff up jarreth :D
#12 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 14 May 2007 - 05:55 PM
scored a gss341 walbro pump for 170 + for extra hose just incase.
now just need to put the fucker in!!!
might wait till mourning.
#13 nissanman
Posted 14 May 2007 - 05:57 PM
Ive heard ALOT of crap about them, not just one instance.
Put simply, why wud these be nearly half the price of a similar item, they both produce same rate etc.
Im in the market for Fuel pumps also... and can say.. i wont be touching the WALBRO stuff.
Either GTR pump or Bosch 040.
#14 Ozchuck
Posted 14 May 2007 - 09:07 PM
Dont use a GTR pump, go for a proper upgrade.
Also, theres tonnes of walbro copies on the market and they are heaps less reliable.
My walbro is working fine.
#15 nissanman
Posted 14 May 2007 - 09:15 PM
The GTR pumps pump a higher rate than a 040... but its second hand so...
Well there ya go. I dunno the ones i have heard of and me mates must be copys n a load of junk lol.
he got his frm ebay so... gota watch b careful..
#16 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 14 May 2007 - 10:54 PM
my walbro is now also working fine :P :yes: :yes: :D
#17 cammo
cammo
  • 160 posts
Posted 14 May 2007 - 10:55 PM
if he did a 040 or any other external pump he would still have to replace his intank pump anyways! because he needs a way to lift the fuel! a good intank pump will do the job very easily!!
#18 al3x
  • 344 posts
  • Car:CA18DET S12 Hatch
Posted 15 May 2007 - 12:16 AM
Sounds like you had the same problem i did before i installed a Walbro pump.
Is your new pump louder then the stock gazelle one?
#19 Buster
Buster
    Lens Monkey
  • 499 posts
Posted 15 May 2007 - 06:25 AM
no, its much much much quieter, feels much better under foot tho even in the ca20.
still need to get new hose clamps, and i put the float in the wrong position, so the guage is dead atm.
now its time to put the ca18det to make use of the walbro.
#20 Nehemiah
Nehemiah
  • 379 posts
Posted 15 May 2007 - 10:18 AM
Good to see it worked out for ya.
Sam
