Replacing the original speakers
13 replies to this topic
#1 Frederic
Frederic
  • 23 posts
Posted 28 April 2007 - 06:19 AM
I'm about to replace the original radio and all the speakers in my S12. But when I removed the back speakers, I couldn't find any indication which cable is negative and which one is positive. Any clues on what to look for color coding wise?
Thanks!
Edited by Frederic, 28 April 2007 - 06:20 AM.
#2 nissanman
Posted 28 April 2007 - 11:08 AM
lol, yea i think every one has same problem.
i found that the ones with the white stripe are negitive and the pink sripe dwn them are positive. :) in my case anyways.
#3 Nehemiah
Nehemiah
  • 379 posts
Posted 28 April 2007 - 02:09 PM
It wont matter the speaker will work either way (as long as they are both wired the same way).
See: http://www.madsci.or...44118.Eg.r.html
By "correct phasing", what's required is that all the speaker cones
move in the same direction when the source amplifier(s) apply a voltage of
a given polarity. This synchronization ensures that when the amplifier produces
a positive voltage, all the speakers compress the air in front of them. If
care is not taken in this regard, some speaker cones are compressing the
air while others are expanding the air -- effectively, the speakers are
working against each other.
As long as you chose a wire and stick to it itll work.
Sam.
Edited by Nehemiah, 28 April 2007 - 02:18 PM.
#4 Guest_4GOT10_*
Guest_4GOT10_*
Posted 28 April 2007 - 02:15 PM
^^^agreed
#5 nissanman
Posted 28 April 2007 - 02:16 PM
It wont matter the speaker will work either way.
Thats tru :) but it will be inverted... and can tell the sound quality difrence for sure.
#6 Nehemiah
Nehemiah
  • 379 posts
Posted 28 April 2007 - 02:26 PM
Yeh I was thinking about it a little more and although the speakers will "work" apparently the sound stage will fruck itself because the rear speakers are out of phase with the front ones.
Try it both ways?
Sam.
#7 Guest_4GOT10_*
Guest_4GOT10_*
Posted 28 April 2007 - 03:18 PM
takes 2 seconds to swap two wires around
#8 Frederic
Frederic
  • 23 posts
Posted 28 April 2007 - 07:19 PM
The original speakers were actually marked, but barely visible! I've filled in the markings here for clarity:
Since I might want to be able to restore the car later, I decided to use the connector from the speakers to build my own speaker adapter.
Bend out the bottom tab:
De-solder the wires to the speaker:
The removed speaker connectors:
Just solder the new speaker wire to the old speaker connector and presto - finished original speaker to new speaker adapter:
If you look closely at the picture, you can make out the color coding of the original wiring.
And of course, just reverse the process to restore your car to it's original state.
Unfortunately, the budget speakers I bought actually sounded worse than the original factory fitted Clarions...
Edited by Frederic, 28 April 2007 - 07:56 PM.
#9 = SR S13 =
= SR S13 =
  • 403 posts
Posted 28 April 2007 - 07:23 PM
hmmm if you were like a week quicker i could have sold you some good speakers for cheap :yes:
#10 Fury-S12
Posted 29 April 2007 - 01:12 PM
ye i was goin to say the speakers are marked was sitting wondering how ppl didnt no lol btw put some good 6*9's there and its good substitution for those that dnt want a big sub in the back
#11 Umai Naa!!
Posted 29 April 2007 - 01:59 PM
I had 7x10s in my main drift project for a while, when it was still registered all those years ago.
Subs suck in an S12 hatch, as it hampers all that practicality.
#12 SheppS12
SheppS12
    *Donating Member*
  • 175 posts
Posted 01 May 2007 - 11:34 PM
i just rewired my car audio, but im wierd... i also put in 300W splits into my car...
If your after a cheap decent pair of 6" speakers look at rogers, if u can get them through ur local strathfield, if not spend the extra $100 and get some of a brand names speakers from last year, last seasons stock will always sell a lil cheaper than the new stock, because they dont look the same as this years model, or have maybe 10w diffecence
<a href="http://www.elusive-e...ertainment.com" target="_blank"><img src="http://i47.photobuck.../signiture.png" border="0" class="linked-sig-image" /></a><br /><a href="http://www.elusive-e...ertainment.com" target="_blank">Melbourne Dj</a>   <a href="http://www.elusive-e...ertainment.com" target="_blank">Dj Hire</a>   <a href="http://www.elusive-e...ertainment.com" target="_blank">Elusive Entertainment</a> <a href="http://www.elusive-e...ertainment.com" target="_blank">Mobile Dj</a> <a href="http://www.elusive-e...ertainment.com" target="_blank">Dj</a>
#13 Guest_4GOT10_*
Guest_4GOT10_*
Posted 02 May 2007 - 07:11 AM
Frederic
Group: Members
Anthony, :yes: i dont think they have Rogers or Strathfields in Sweden :yes:
#14 SheppS12
SheppS12
    *Donating Member*
  • 175 posts
Posted 09 May 2007 - 09:01 PM
they should have rogers, there a british brand, now made in hong kong though ;)
and i didnt notice the sweeden bit, sorry Fredric
