S13 Trans swap for a SE
1 reply to this topic
#1 Ju_S12_Turbo
Ju_S12_Turbo
  • 5 posts
  • Name:Julian
  • Car:1987 200SX SE
Posted 17 July 2012 - 06:36 PM
Everyone and their mom has done this for their S12, but not to many SE people have (that have posted at least) Thanks to "nismologist" and "David B" for the info I got from them (I will point it out). Here a link that helped me http://club-s12.org/...p?topic=25767.0
The Exact parts I used were, Side note, I say 240sx a lot because from my understanding the 180sx/200sx (any not ka24de) has a different front driveshaft.
1990 240sx Transmission (ka24e)
1993 240sx Front half of Drive-shaft (ka24de)
Stock SE Trans mount/Dog bone (slotted main mounting holes to fit )
SE Front flange on the 240sx Drive shaft.
Sadly I didn't take many pics but I have a few and a lot of pointers for problems I ran into.
First nismologist said that all his mounts lined up perfect, they didn't for me. I had to slot at least 2 of the holes for the stock tranny mount to work, it could be because I am running a billet aluminum mount but it fit perfect before so meh.
What nismologist said about the SE/240sx(s13) drive-shaft is true (Major help ) and you have to impact your old flange off (bigger bolt holes and farther apart) and put it on the front half of the 240sx(s13) drive-shaft. This is the piece I am talking about
[img width=433 height=768][url="http://img.photobucket.com/albums/v203/Ju_S12_Turbo/Forum%20pics/000_0154.jpg"]http://img.photobuck...cs/000_0154.jpg[/url][/img]
Now you can take it to a drive-line shop if you have one local and if you uncomfortable with doing it the way David B (and me thanks david!) said by knocking off with a hammer. If you do it with a hammer, be sure you go from opposite side each hit and same with putting it back on. Be sure you crush the nut once it is tight .
[img width=1024 height=768][url="http://img.photobucket.com/albums/v203/Ju_S12_Turbo/Forum%20pics/100_2075.jpg"]http://img.photobuck...cs/100_2075.jpg[/url][/img]
Now, for the biggest problem I ran into which 90% of people will never run into, but at least people know. If for whatever reason your input shaft cover breaks (thing that covers up the bearing and the throw out bearing glides on) a 240sx will bolt on, BUT it will put the clutch fork pivot point in the wrong spot. You can get a replacement online for 50$ shipped from www.nissanparts.cc (part number 32111V5001), if you need one asap you can get one from a Non-turbo Z31/300zx 84 and up (http://nissan4u.com/...nfo/32111V5001/). If you have a welder or a friend with a good welder you can do this!
[img width=1024 height=768][url="http://img.photobucket.com/albums/v203/Ju_S12_Turbo/Forum%20pics/IMG_20120612_210100.jpg"]http://img.photobuck...0612_210100.jpg[/url][/img]
[img width=1024 height=768][url="http://img.photobucket.com/albums/v203/Ju_S12_Turbo/Forum%20pics/IMG_20120612_210114.jpg"]http://img.photobuck...0612_210114.jpg[/url][/img]
Also you are going to need to cut the shifter spot back (Closer to you and better imo) by about 2.5 inches and you will need a 240sx shifter plate (S12 one only has 5 bolt holes that work, the normal big hole is not threaded on 240sx's) . There is also a extra sensor on the 240sx trans on the tail shaft housing, you don't need it but if it is missing your gonna have a bad time lol.
If you Decide to take the tail-shaft housing off (I would to check gear and stuff) make sure you put the shifter thing in (thing that goes onto the shift rod and what the shifter slides into, I forgot what its called lol) as you put the tail-shaft housing on or you will never get it on lol. I used my Stock Speed sensor and it mated up fine and reads the same speed (Gps verified ) as before.
As for gaskets, I Honestly Use RTV (The stuff I used http://www.permatex....asket_Maker.htm) And just cleaned up all the mating spots with a razor and brake clean until nothing came off with a clean shop towel. Though I did reused my input cover gasket but I also put rtv on both sides and change the input seal at the same time. When you put everything back on make sure you put the bell-housing cover/spacer (thing that goes on the back of the motor) if you don't, your gonna have a bad time lol.
It honestly wasn't to bad, just take your time on stuff and try not to mess with the gear/shift forks with the case is off because if you do, well you might not be super stoked if the gears don't do what they are suppose to do lol.
Edit: No idea why the pics are not showing up, I'll figure it out tomorrow lol.
Edited by Ju_S12_Turbo, 17 July 2012 - 06:43 PM.
#2 Ju_S12_Turbo
Ju_S12_Turbo
  • 5 posts
  • Name:Julian
  • Car:1987 200SX SE
Posted 18 July 2012 - 06:58 AM
Also, Can you not edit your post after certain time? If a mod could delete the first post that would be killer.
Edited by Ju_S12_Turbo, 18 July 2012 - 07:01 AM.
