SR20 Part Numbers
No replies to this topic
#1 Candellan
Posted 13 April 2010 - 12:32 PM
Part type
Nissan Australia part number
Other source or comments
Oil filter
15208-H8911
Ryco Z145A (CA18 all?)
Door bump rubbers
01658-J7000 (Skyline R31)
Exhaust manifold gasket
14036-D4200 (EXA 1.8, S13 CA18)
Four separate pieces
Intake manifold gasket
14035-D5710 (CA18 all)
Injector rail to cylinder head
14035-D5711 (CA18 all)
Injector rail to intake runner
14035-53J10 (SR20 all)
Turbo inlet flange gasket
14415-75F10 (200SX)
or 14415-17M00 (S13 all)
The Aust 200SX one fits.
Turbo outlet flange gasket
14445-26E00 (S13 all)
Engine front oil seal
13042-42L00 (CA18 all)
Engine rear oil seal
12279-18V00 (CA18 all)
Oil pan seal front
11121-01F10 (CA18 all)
Oil pan seal rear
11121-01F15 (CA18 all)
Head gasket
11044-51E00 (CA18 all)
Head gasket
11044-50F00 (SR20)
until 9/92
Head gasket
11044-50F01 (SR20)
from 9/92 till 7/93
Head gasket
11044-50F10 (SR20)
from7/93 onwards
Engine gasket kit
10101-51E25 (CA18D)
Engine rebuild gasket kits
Engine gasket kit
10101-56E25 (CA18DET)
Engine gasket kit
10101-50E25 (SR20DET)
Engine gasket kit
10101-51E26 (SR20D)
Valve grind gasket kit
11042-51E25 (CA18 all)
11042-50F25 (SR20 all)
Fan belt
11720-V7301 (CA18 all)
L = 855mm
Fan belt
11720-52F00 (SR20 all)
Compressor belt
11920-V7301 (CA18 all)
also suits power steering pump
Compressor belt
11920-30R10 (SR20 all)
Water pump
21010-V5528 (CA18)
until 8/90
Water pump
21010-V5529 (CA18)
from 8/90
Water pump
21010-52F00 (SR20 all)
Thermostat
21200-V0201 (CA18 all)
82.0 C
Thermostat
21200-V0206 (CA18 all)
88.0 C
Thermostat
21200-53J00 (SR20 all)
Radiator cap
21430-01F01
Radiator hose - upper
21501-35F10 (CA18 all)
Radiator hose - lower
21503-35F00 (CA18 all)
21501-52F00 (SR20 all)
21503-52F00 (SR20 all)
Bonnet bump rubbers (large)
62840-D0100 (Skyline R31)
Engine coolant
10120-89904
Castrol
Dash switch back lights
Nissan Aust, have similar types
$11.00 each
**** Smith P8130, with fiddling needed or 12v lamps WT2-12 from WES Components, good fit. 65c each
Radius rods (Tension rods)
54468-35F20 (S13 all) includes bush
Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ).
Wheel nut
62840-21001 (R31 Skyline)
Brake pads
See service info page.
Bendix and others.
Headlight globe
Who cares
Any brand. H4 60/55W 12V or H4 100/55W 12V the second one has 100Watt high beam.
Rear Dampers
( shockers )
See Nissan Dealer or Nismo
KONI. Part no. 80-401-081 sports kyb.
Approx $315 a pair.
Fuel filter
16400-F5100 (CA18 and SR20)
RYCO Z202
Air Filter
16546-V0100 (same as R31 Skyline)
K&N high flow reusable type P/N 33-2031-1
Spark plugs
22401-58S16 (PFR6A11, CA18)
Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm)
Spark plugs
22401-53J16 (PRF6B, SR20DET)
Crank angle sensor
23731-85M10 (CA18 all)
Crank angle sensor
23731-50F01 (SR20 all)
Coolant temp sensor
25080-89903 (S13 all)
Oil pressure sender
25240-89920 (S13 all)
