Hey there! We've noticed you are a Guest. Why not register with S12Silvia.com to take full advantage of our many features. Like most online communities you must register to view or post in our community, but don't worry this is a simple free process that requires minimal information for you to signup. Be a part of the XII revolution by signing in or creating an account.
factory temp guage
#1
Posted 02 April 2010 - 11:00 PM
#2
Posted 03 April 2010 - 06:48 AM
#3
Posted 03 April 2010 - 07:59 AM
When we ran Piggie, we used the CA18 sensor, which worked fine with the S12 gauge.
Bare in mind, when you wire up the CA18, the same sensor provides a temperature signal to both the ECU and the gauge. The CA20 is different, and has two separate sensors.
Posted 03 April 2010 - 01:20 PM
I've got a CA20 sender here, and possibly a CA18 one here too, if you want to try them out when you come down to pick up the other stuff.
HMM, 2 seperate sensors, what i did was hacked the purple wire at the back of the dash and ran it to the SR ECU temp wire on the white plug... Maybe thats why it gets that type of reading?
#5
Posted 03 April 2010 - 04:33 PM
Is the temperature sensor wire on the SR blue with a black trace?
Posted 03 April 2010 - 08:23 PM
#7
Posted 04 April 2010 - 08:36 AM
yes
Yea thats the wire, i was luck enuff too that my Tacho sensor wire still got a signal as well, so i didnt have to root around to get my aftermarket one going.. That works ok, i had a scrounge on the net, people say that the voltages from car to car and guage to guage vary, i think the SR has a higher one maybe than the CA did, hence the higher reading..
