Welding a H190 diff
35 replies to this topic
#1 Ozchuck
Posted 19 August 2006 - 01:53 PM
Hey, I wanna weld my diff on my S12 that has a H190
Would it be abel to back the car up onto ramps, so that the rear is in the air.
Then I'm assuming I unbolt the driveshaft from the input yoke, then remove the... Bellhousing? whatever it is, the bell shaped doozy where the driveshaft attaches and has bolts all the way around it.
if I take that off will I have the space required to access all the spider gears enough to weld her up?
Or will I have to do more?
#2 FLY PSI
FLY PSI
  • 443 posts
Posted 19 August 2006 - 03:05 PM
you will need to remove the entire centre from the car to get access to the spider gears.
jack the car up in the air, take off the wheels and the covers of the drums, then undo the 4 bolts that hold the axle in. then pop the axles out.
Next get under the car and unbolt the tailshaft, then undo all 10 bolts holding the centre in the housing, make sure you drain the diff first so you dont get oil everywhere. then completey remove the centre from the car. take to baench clean up oil and then weldaway. i put plates in mine that were chamfered to seat properly. then welded them in. put something in the axle splines so you dont get spatter in there.
There's something about Drift............Posted Image
#3 Ozchuck
Posted 19 August 2006 - 03:22 PM
Ah, so there difinitely is no lazy mans way?
Bugger!
Thank you so much for offering the best information I've ever had regarding this.
Searches reveal 20 page arguments of wether or not it is a good idea, nothing step by step, cheers.
#4 FLY PSI
FLY PSI
  • 443 posts
Posted 19 August 2006 - 04:11 PM
Not with a H190,
if you could take the backing cover off it would be easy, we have done a few early rolla's like that *KE30 and earlier* we would just jack the car up remove the back cover and weld away, most of the times we would accdentlly weld the axles in but that didnt matter as when something broke we just replaced the lot and did it all over again. btw the car im refering to was a KE30 with an SR20DET :o unengineered and with all std brakes and suspension. (F@#k that thing was dangerous)
#5 Shinigami
Shinigami
    Birthday Nugget
  • 668 posts
Posted 19 August 2006 - 06:29 PM
Lucky for me when i bought my gazelle the h190 diff was already welded definatly saved me from doing it lol :P :o
John
** Drive It, Like You Stole It **Posted ImageTouge and Drift Lover >.
#6 Pistonfreak
Posted 19 August 2006 - 07:34 PM
If your locking one up, try to do a diff centre out of a automatic car.
They have better ratio's
Even better is the center from a 720 diesel ute.
Weld the spider gears only. You get too much heat if you try to weld the whole center up.
Heat = warped noisey diff
Then put it in your housing.
It makes the job easier when ripping the whole diff apart, because you'll have a complete centre ready to go back in.
#7 FLY PSI
FLY PSI
  • 443 posts
Posted 19 August 2006 - 07:48 PM
what ratio's are the auto diff's? and the 720's??
Ive got a 3.9 at the moment and i think its abit tall for drifting.
#8 DRIFTKID
DRIFTKID
  • 670 posts
Posted 19 August 2006 - 08:25 PM
i took mine to an engeneering place... they welded the entire center, hope it goes well im sure they know what they are doing with metals... after all its there trade!!
welds look to be of alot better quality then my last job (mechenic mate)
only cost me 25 bucks 2!
ill let u know how it goes...
RIP GAZELLEBuy my parts!!!
#9 Pistonfreak
Posted 19 August 2006 - 08:59 PM
The one I have now is 4:3.1
The only time i've blown a H190 was when you were at the track Driftkid.
Note to self. no drifting same day as driftkid. lol jks
#10 Shinigami
Shinigami
    Birthday Nugget
  • 668 posts
Posted 19 August 2006 - 09:19 PM
i like my welded diff because when you go over a speedbump while turning the car flicks itself straight really funny especially when ppl are watching your car from behind theyre like WTF lol :P :o
John
#11 Umai Naa!!
  • 4,240 posts
Posted 19 August 2006 - 09:26 PM
Manuals were 3.7, and autos were 3.9
#12 FLY PSI
FLY PSI
  • 443 posts
Posted 19 August 2006 - 09:30 PM
HMMMM that would make mine 3.7 then :o
#13 Umai Naa!!
  • 4,240 posts
Posted 19 August 2006 - 09:39 PM
Check your axle code on the build plate. Should be HE37 for a 3.7 diff, or HE38 for a 3.9.
Also, next time you pull the centre out, count the teeth.
For the 3.7 it should have 37 on the crown wheel, and 10 on the pinion.
OR, 35 on the crown wheel, and 9 on the pinion for the 3.9
#14 DRIFTKID
DRIFTKID
  • 670 posts
Posted 19 August 2006 - 09:53 PM
haha yeah awsome day!
i thought u must of odne an axle did u snap welds in diff or osmehow manage to destroy the crown and pinion?
have to do it again very soon :o
u had the full pro style pit setup and all!!
also have some video footage of u... and exactly when u blew it up as well (i was behind you)
when i move down and figure out how ot transfer it in good quality ill give u a copy
Christian
#15 Pistonfreak
Posted 19 August 2006 - 11:05 PM
you think i'm pro style . lol
You should Ash's ramps he lays out.
#16 Umai Naa!!
  • 4,240 posts
Posted 20 August 2006 - 06:21 PM
He even gets randoms like me to line them up skew-if for him :P
#17 FLY PSI
FLY PSI
  • 443 posts
Posted 20 August 2006 - 09:54 PM
The trusty S12 Pit crew :P I seem to remember you helping to stop my car sliding off sideways :rolleyes:
My axle code is HE37 so 3.7:1 for me :huh: i think i should try a shorter diff. ;)
#18 Ozchuck
Posted 12 September 2006 - 04:30 PM
GYARR I'VE BEEN UNDONE!!!
The drum covers refuse to budge, wtf?
I've tried hammer taps, WD40, screwrdivers.... wtf moite?
#19 ferret
ferret
  • 309 posts
  • Name:Jaimie
  • Car:Guzzle and Friends
Posted 12 September 2006 - 06:11 PM
I believe that 720's have 4.56 gears in them, apparently 720's have an R200 in the front, and I'm thinking that a set of 4.5's would go very well under my car. Either that or it's Navara's and Pathfinders that have the R200 front diff, and I think they're either 4.11 or 4.56 depending on engine and gearbox combo's.
Hiding under the bed....
#20 FLY PSI
FLY PSI
  • 443 posts
Posted 12 September 2006 - 07:07 PM
there is two threaded holes, i think its an M8 thread, just put some bolts in there and it will slowly come off.
remember to do them up evenly so it comes off straight. :)
